Quote:
Originally Posted by F_R
You put oil in the gas. It goes straight through the motor with the gas. Some gets burned (smoke) and some goes out the exhaust. That is exhaust blowing out with that water. So, it has oil in it. No fix needed.
FR ,I am almost scared to ask but here goes, you responded with the above quote to Charlston Glasmaster last august , will Seafoam also cause a residual of oil around the inside wall of the prop,mine has this that I have not noticed before I put the Seafoam in the tank,mine is a 93 115 and like his it sounds and runs strong but seeing the oil gave me a start ,so I will wait for your response to this before I go again, as not to take any more chances than are neccessary.Thanks
Kelly B. Okla.
