Re: longshaft on shortshaft transom
No drawbacks, you can run it like that .... I have before, it does create drag and won't perform to 100% of it's ability but you will move forward if that is what you are asking, it is not always that water will splash back into the boat ..... make sure your boat is properly inflated and give is a try ..... make sure the motor's trim is set up nicely ....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
