Piston Rings
I have a 1958 Evinrude 18 hp. I have searched high and low to find the piston rings so they could be replaced. Can anyone give me an idea as to where I might be ably to find them? Also when I seperated the lower unit from the power head I thought there was only one seal that went on the lower unit. Can anyone help me out there as well? Thank you Bill
F_R
Re: Piston Rings
You must have not searched high or low enough. The part number is 378415 (set of 3 rings). Any Evinrude or Johnson dealer can get them. Or there are on-line sources too.
I don't understand the second question. Please elaborate.
Re: Piston Rings
Well thank you for the response Imported. As for the second question I was able to find a diagram that helped me. Now is there anystores online that you would recommend to find evinrude parts that would either have them or be able to get them?
