MercMonster
- Jun 3, 2007
- 151
I've been working on pulling the drive from the engine all evening. Manual says to "carefully remove drive" from the boat, but this thing is being a bear. I believe drive is Mercruiser I or R, really can't get a square answer from anyone. (Head of the drive has the loop for hoisting the drive and the ribs across the area where the vent screw is - Serial# 4448631) Anyhow, the head on the old engine still in the boat is removed and I could get back there with a flashlight and see the start of the shaft splines where they meet the coupler going in and there is some very light rust on the splines. Can that little amount of rust be causing the trouble? I used 3/4 can of WD-40 spraying on that spline and then move the shaft back into the coupler to try to work it back in there (I'm getting the drive pulled out about an inch total and thats as far as she goes). The gear is in full forward position. 6 bolts have been removed and trim cylinder rams are removed. My thought tomorrow was to point the bow downhill so gravity would get the WD-40 further back onto the spline part in the coupler. The "new" engine is ready to go, after a few small parts off the old engine when it comes out. What else could be holding the drive on? Would turning the prop counter help to get it off or is that just for getting it on? Drats....I'm at a standstill til this things comes off
