  #1
Old August 15th, 2007, 12:43 PM
JPritch JPritch is offline
Default Yamaha F60TLR: Water in Fuel
Was riding at WOT and the engine started losing power and would cut back to lower rpms. Got back to the ramp and started diagnosing, and noticed the bobber in my fuel filter cup had risen, meaning there was water in my fuel. I drained the cup, and went back out and encountered the same problem, and the bobber had risen yet again.
I have an inline fuel/water separator between the tank and the outboard.
Before I take it to the shop, I was wondering if you all could suggest how I can go about trying to solve this issue myself. I was thinking I could drain the fuel, install a new fuel/water separator, and inspect the fuel system components for leaks, then put new fuel in, and run the engine with the muffs and see if the bobber rises again.
Another question I had was whether the Yamaha fuel/water separators need to be drained after they separate out a certain amount of water. I've seen other brands that have a drain, but don't see one on mine. Wondering if it's full and no longer separating water?
Thanks in advance for all replies!
  #2
Old August 16th, 2007, 07:25 PM
rodbolt rodbolt is offline
Default Re: Yamaha F60TLR: Water in Fuel
most likly the water seperator is full of water and is now passing it along. it should be changed very 6 months regaurdless.you may have a fuel tank or fill cap leakingas long as it has not gotten to the VST I would change the water seperator andclean the engine filter, there is a drain on the VST you can open and see if any water made it to the VST.
  #3
Old August 17th, 2007, 11:54 AM
Thank you for your help Rodbolt.
I have a spare separator, so I'll go with your recommendation and see if that fixes the problem.
Excuse my ingnorance, but what is the VST? And if water made it to the VST, what course of action should I then pursue?
  #4
Old August 17th, 2007, 05:31 PM
Ok, did a little research...Vapor Separator Tank.
Good thread here: http://www.thehulltruth.com/forums/t...163374&start=1
Hopefully nothing has messed up my VST. Sounds like more work than I'm qualified to do!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Floscan on Yamaha vs Yamaha Fuel mgmt 96century Yamaha & Suzuki Outboards 0 February 27th, 2006 09:02 AM
Yamaha water separating fuel filters drfish18 Yamaha & Suzuki Outboards 3 February 11th, 2006 06:28 PM
Yamaha 3.0 Stern Drive - Fuel Filter/Water Separator Spring Franky_Toolbox Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 July 5th, 2005 10:24 AM
YAMAHA 10 MICRON WATER FUEL SEPARATOR LOYD Yamaha & Suzuki Outboards 3 June 20th, 2005 03:32 AM
fuel/water separator for 40hp yamaha c-ya Yamaha & Suzuki Outboards 5 February 24th, 2003 11:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
