  #1
Old August 15th, 2007, 11:04 AM
jedimaster jedimaster is offline
Default Temp guage for 200 evinrude?
Just wondering if its possible or if anyone installs a temp guage in a '91 200hp evinrude? Also how come it doesn't come with one?
  #2
Old August 15th, 2007, 11:06 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: Temp guage for 200 evinrude?
It's very possible. The motor doesn't come with any gauges or controls from the factory. Or a prop. You chose what you want.
  #3
Old August 15th, 2007, 11:11 AM
How would I install a temp Guage? Does it measure the water temperature exiting theblock or the water temp in the block?
  #4
Old August 15th, 2007, 01:33 PM
Silvertip Silvertip is offline
Temp gauges can be installed on your engine and they measure one of two things depending on the sensor you choose and where it's mounted. If the gauge comes with a sender that screws into a port in the water jacket, it measures water temperature in the block. If it has a sender that mounts to the cylinder head using a headbolt, it is technically a cylinder head temperature sender. Either way, the sender must match the gauge you buy. Teleflex and Faria both offer them. DO NOT buy a gauge calibrated 120 - 240 degrees as these are for I/O's and Inboards. Outboards run much cooler. Although there aren't many around any more, an outboard gauge should read 60 - 220 or so. Most outboards at idle run in the 120 - 140 range and drop somewhat when the bypass valve opens at higher speeds. Many outboard gauges are now calibrated "C - N - H" (cold, normal, hot). Ideally on your engine you should have two senders, one for each head and switch that allows you to alternately monitor both sides of the engine. Monitoring one side is of little help if its the other side that's running hot.
  #5
Old August 15th, 2007, 02:25 PM
Thanks, that makes sense.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Evinrude 140 Temp guage kit ? Theoutdoorsman Johnson & Evinrude Outboards 2 October 6th, 2006 12:00 PM
Temp Guage VisionIsle Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 February 27th, 2006 07:37 AM
TEMP GUAGE STEVEGOLD Boat Topics and Questions (not engine topics) 7 June 24th, 2005 04:26 AM
How to install Evinrude 175 temp/pressure guage. edboat Johnson & Evinrude Outboards 1 May 26th, 2003 09:10 AM
temp guage nh3 Force & Chrysler Outboards 1 August 5th, 2001 07:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
