  #1
Old August 15th, 2007, 10:21 AM
clmdpk2 clmdpk2 is offline
Default question about mercury throttle control
Hi everyone. I'm a new member and also a new boat owner. I'm finding out how little I know about boats every day!!! We have a 25 foot pontoon boat with a Merc 50 hp engine. It has been running ok until yesterday when the engine stalled while we were out. Had to be towed in and could not get it started again. Once back at dock someone suggested it might be something with the throttle control. We are now able to get it started with the throttle in the wide open position, but it stalls when I put it into neutral. The engine runs fine when the throttle is up but stalls immediately when I try to put it into neutral. A friend told me take the throttle cover off and inspect the inner workings where the button that pops out when put into neutral lies. He said sometimes the button gets stuck and doesn't truly pop out. I tried to pry the housing cover off from the outside but it won't come off. There is no screw or bolt to take it off. There is a small hole on top, but doesn't seem to have anything to do with getting it off. On the inside of the housing are four screws that are thredded but have rubber like gromets on them and it also doesn't want to come off. Can anyone enlighten me as to how to get the cover off, and what to look for once it is off?? Remember, I'm really a dumb novice!!!!!
  #2
Old August 15th, 2007, 11:56 AM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: question about mercury throttle control
Welcome to iboats.
Remember, all of us were new to boats at one time or other.
Let's get this up to the Mercury Outboard and Mariner Outboard troubles and repair forum.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old August 15th, 2007, 02:48 PM
Laddies Laddies is offline
There is nothing wrong with the throttle control, you have either lost spark on 1 or more cyls. ck them for spark or it has a flooding condition chances are you have a inlet needle stuck in 1 of the carbs or a fuel pump with a bad diaphram
  #4
Old August 15th, 2007, 09:45 PM
crabbie crabbie is offline
I don't know enough to say whether the controls are a problem, but having just had to replace mine, I know a little bit about taking controls apart.
Your controls don't sound familiar, though. The two types I've had are from the 70s and 80s, and both have to unmounted from the side of the boat before you can take them apart, as the screws are on the back. But be careful, sometimes pieces will come springing out at you when you open the box up.
If you do get it open, what's inside won't make any sense initially, so might not be helpful. Better to try checking the motor, first.
Actually, for SURE check the motor first: if you really think it's the controller, then you can disconnect the cables from the motor and push on the throttle lever yourself to see if you can replicate the problem. If you can, it's a problem with the motor. If not, well... could still be either. The joys of debugging...
rodney (only slightly less dumb novice)
  #5
Old August 17th, 2007, 05:55 PM
Question Re: question about mercury throttle control
Thanks for the tips. I had someone who "supposedly" knows what he's doing look at it and he said the throttle control was ok, but that in checking the compression, one cylinder was testing at about 90 while the other two were at 125. He says this is the problem and that the engine is no good now and needs to be replaced! I don't know enough about motors, but think they can be repaired. Is he just trying to sell me a new motor?
  #6
Old August 17th, 2007, 06:02 PM
renny1 renny1 is offline
i had the same sort of readings and one of my pots was only reading 90 so i de-carboned it (if thats the word) an she is now reading roughly the same try it before you get ripped off
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Throttle / Remote Control question - need help please valkyr Boat Topics and Questions (not engine topics) 12 February 24th, 2008 12:03 PM
Throttle Control Question Flying Dutchman Johnson & Evinrude Outboards 5 May 29th, 2007 03:37 PM
Question on Throttle control Chris611 Boat Topics and Questions (not engine topics) 1 February 5th, 2005 03:26 PM
Mercury shift/throttle control problems airwalkin Boat Topics and Questions (not engine topics) 3 July 14th, 2004 08:43 PM
Mercury throttle control seems slip rangerb Non-Repair Outboard Discussions 3 March 16th, 2004 02:56 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
