  #1
Old August 15th, 2007, 09:07 AM
frosty1 frosty1 is offline
Unhappy fuel leak 96 YAMAHA 200hp carb
I have a fuel leak I'm trying to solve. In checking the forums the 2 most likely causes should have been the needle valves/floats in the carburetors, and or the fuel pump diaphrams.
It was 1st noticed last season when trimming the engine up at the end of the day dripping from drain holes in the lower unit area. At all times the engine ran perfect.
This year I'm trailering and have a better opportunity to flush out and examine the unit running with the fresh water adapter. I had some time and chose to rebuild the 3 carburetors. New needle valves, gaskets and removal and cleaning of the high and low speed yets and air yets. re assembled and ran again. The engine started even better and runs smooth - but still the leak.
Upon close inspection I see the fuel begins dripping from under the drive shaft after it runs for about 3 minutes or so at idle. From there it drips into the housing and thats where it finds it way to the lower unit and explains why it comes out when trimmed up.
The motor has 550hrs on it, si I chose to install 2 new fuel pumps 40 bucks ea to eliminate a chance of leaking diaphrams. Started up optomistically and sure enough - same problem.
2nd guessed my carb rebuild and took them off again to inspect the floats and needle valve set up. all needle valves free but 1 float a little crooked. Replaced that float, asembled and tried again. Same problem- 3 minutes or so and dripping fuel from under the drive shaft.
I had checked the float height to the manual, and was pretty close, but maybe a little low on all. I may take them off 1 more time and try to adjust the floats higher to spec in case the fuel pressure is unseating the needle valves. This will be the last try before bringing it to the shop.
Anyone have any suggestions for what else the cause may be?
Frosty1
  #2
Old August 15th, 2007, 11:12 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
Default Re: fuel leak 96 YAMAHA 200hp carb
did you you rebuild with all new parts and set them at 14mm the floats?
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #3
Old August 16th, 2007, 08:58 AM
Yes I used the yamaha rebuild kits. Reused the floats, but felt the settings were close enough. They were all below 5/8". Hoefully that turns out to be the problem.
I'll be breaking them down again and setting to .630" approx 5/8: which is the spec in my manual + - .020". I'm thinking the float level dropped over time and may be not keeping enough pressure on the needle valves at idle once the fuel pumps build pressure.
I hope it works.
  #4
Old August 16th, 2007, 11:55 PM
JUSTINTIME's Avatar
throw the selco away
get a yami manual for the right specs
no yami uses inches
__________________
  #5
Old August 19th, 2007, 11:23 AM
FYI- I use a Yamaha manual lit-18616-01-41 which gives the setting in both mm and inches.
it is 16mm + -.5 or .630 +- .020. not 14mm.
Thanks anyway. I reset all to specs and it is better.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fuel leak below top carb kapaafire Johnson & Evinrude Outboards 1 March 8th, 2007 02:42 AM
Help! Carburetor Fuel Leak - 1989 60HP 2 Carb, 3 Cylinder fuel leak from Jet wgstelz Mercury & Mariner Outboards 1 September 23rd, 2006 07:51 PM
major carb fuel leak wormboy Johnson & Evinrude Outboards 2 August 9th, 2006 04:25 PM
Evinrude 150 carb fuel leak jeff151888 Invader Boats 1 July 29th, 2006 03:18 PM
2001 yamaha 4 stroke carb fuel leak alotto Yamaha & Suzuki Outboards 7 October 17th, 2004 09:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
