  #1
Old August 15th, 2007, 09:05 AM
Andre Andre is offline
Default Weak power trim/tilt on 90 Evinrude
I am hoping someone can help me with this liveable problem since it doesn't stop me from operating my boat. When I use the power trim during low speeds <15KM (I am guessing 8MPH for you US folks) I have no issues raising or lowering the power trim. The faster the boat goes the weaker the system is to the point it doesn't move. When idling, it moves up and down perfectly. I have had this issue since I purchase the boat and motor so I know that it's not the 10Amp stator plate. I had an issue with the stator plate and timer base which I have since replaced. I have not checked the liquids in the trim because the system operates okay at low speeds but if the expects think its a possible reason for this problem, I can certainly do that.
Thanks,
Andre
  #2
Old August 15th, 2007, 10:27 AM
darrklim2's Avatar
darrklim2 darrklim2 is offline
Send a message via MSN to darrklim2
Default Re: Weak power trim/tilt on 90 Evinrude
I am not an expert but I had a boat that had a similar problem. My problem was that there were bad o-rings in the lift cylinders. When not under power there wasn't any pressure so it would go up just fine but under power the engine creates extra pressure to push up and then it wouldn't move. Maybe you have a similar problem with your o-rings or seals.
  #3
Old August 15th, 2007, 06:17 PM
Without getting into dissassembly could you tell if this was the problem by the amount of oil in the piston or signs of oil on the piston rod?
Thanks for your quick response.
  #4
Old August 15th, 2007, 06:25 PM
HighTrim's Avatar
HighTrim HighTrim is offline
I would definately start with checking the oil level in the resevoir. Top it up, cycle it a few times, then re fill it. Make sure there are no leaks and the manual release valve is tight. Your V1 pressure relief valve may be jammed or a bad spring, which would mean taking apart the hydraulics. Do you have a manual??
__________________
Chris
  #5
Old August 15th, 2007, 06:33 PM
I bought a manual after my stator and timer burned out shortly after I got the motor. I got lucky and found some used parts for $50.00 and then spent two weeks chasing down a pinched timer base wire that I inadvertantly grounded to the chasis during regulator re-essembly. The manual has a good description for the power tilt which I will use as a guide. I'll try your suggestion before going deeper into the problem. Summer is nearly over so no point in getting my hands too dirty until after the season is over.
Andre
  #6
Old August 15th, 2007, 10:15 PM
MarkV_Deep6's Avatar
MarkV_Deep6 MarkV_Deep6 is offline
Hi Andre
This is a similar issue I have on my TT. I don't believe there are any hydralic trouble shooters here on the board. I have read the OEM manual and all the trouble shooting in the manual.
I have logically (in my mind anyway) deduced that this issue is caused by orings or seals in the pump control piston on mine. I have rebuilt the TT unit and am loath to go back and get hydralic fluid all over myself again.
The only way this conditions seem possible is if the pressure is not being contained, and is bleeding into the trim up relief side that is designed to release at about 1500 psi, however, the manual states this can be caused by.
Trim up relief valve
Manual relief valve
Trim cylinder sleeve orings, piston seals
Expansion relief valve orings
You really need to have the OEM manual to see the diagrams and trouble shooting charts.
Let us know if you determine the cause of this.
Best of luck!
__________________
25 Hydra Sport
300 V8 Johnson.
  #7
Old April 16th, 2008, 09:01 AM
Thanks for your feedback on this one. It's spring, I replaced my junker of a boat with a much better upgrade and now I have to get the motor trim back in operation.
I really didn't want to get into this too deep but if the procedure doesn't require any special tools then I don't mind going in as a first timer. I am pretty handy and confident in doing this stuff so why not. I also will be pulling the motor off the old boat so the timing is probably good too.
I should know more about the situation within the next few weeks.
Andre
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 140 Evinrude vro -weak trim tilt Salty Sal Johnson & Evinrude Outboards 3 April 24th, 2006 05:56 PM
tilt trim weak JOHNSON110 Johnson & Evinrude Outboards 2 August 1st, 2005 05:45 PM
72 Evinrude power tilt & trim slyshar3 Johnson & Evinrude Outboards 1 July 24th, 2004 07:06 PM
weak trim tilt denniston Force & Chrysler Outboards 2 April 10th, 2004 08:27 PM
115 evinrude power tilt trim screenbuzz Johnson & Evinrude Outboards 6 March 26th, 2002 04:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
