  #1
Old August 15th, 2007, 08:58 AM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Default 1964 Evinrude 75hp, starter maintenance
The starter was making noise and didn't seem to be turning the engine over as fast as it used to. I pulled the starter apart and it has a bushing at either end. I couldn't detect any play but there is play vertically. The armature can move 1/8th inch up and down. There's only one washer on the bottom and two on the top. Should this be tighter?
This starter only has a small drive gear on top so I guess the flywheel drive gear should be looked at as well.
  #2
Old August 15th, 2007, 09:17 AM
Andre Andre is offline
Default Re: 1964 Evinrude 75hp, starter maintenance
This is only a suggestion. The brushs that make contact to the armiture may need a bit of cleaning. Also, check that the brushs are still good and don't need replacing. If they are almost worn out it could be your problem. You can always send it out for a rebuild if you're not sure what to do.
Andre
  #3
Old August 15th, 2007, 09:37 AM
Thanks Andre, the brushes are about 1/4 inch remaining. My manual indicates to replace at 3/8 inch so I guess they are due to be replaced. They look simple enough to replace. There was lots of dust in the bottom cap, likely the brushes.
  #4
Old August 15th, 2007, 10:43 AM
F_R F_R is online now
There are fiber shim washers to take up the end play. Yours must be disintegrated.
  #5
Old August 15th, 2007, 11:27 AM
Now that you mention it, I did find a semicircle of fiber in the bottom cover. That would be it. Do you think that would cause the vibration sound?
  #6
Old August 15th, 2007, 08:13 PM
Chris1956 Chris1956 is offline
Wink Re: 1964 Evinrude 75hp, starter maintenance
If that is a reduction starter, then grease all four bushings, and the drive gear. Clean up the commutator, and check for any shorts.
  #7
Old August 15th, 2007, 10:35 PM
Yup, that's what I did. Didn't check for shorts though. It seems to work better though. Time for a rebuild this fall.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1964 Evinrude 75hp, testing generator Evinrude Boater Johnson & Evinrude Outboards 9 August 26th, 2009 09:53 PM
1964 Evinrude 75hp, reverse lock lever Evinrude Boater Johnson & Evinrude Outboards 6 August 14th, 2007 09:37 AM
1964 Evinrude 75hp, Starts great in a barrel Evinrude Boater Johnson & Evinrude Outboards 7 June 18th, 2007 07:40 AM
1964 Evinrude 75hp, hesitating Evinrude Boater Johnson & Evinrude Outboards 6 June 18th, 2007 07:34 AM
1964 Evinrude 75HP overheating help please seedpws Johnson & Evinrude Outboards 55 August 8th, 2006 01:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
