  #1
Old August 15th, 2007, 12:38 AM
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Default 1960 Evinrude 40 HP, mercury switch
What's the mercury switch for on the throttle? There seems to be two of them side by side but only one wire. My motor stand isn't angled back like a transom so my motor is tilted slightly forward when I work on it. Will this make a difference?
  #2
Old August 15th, 2007, 11:41 AM
F_R F_R is offline
Default Re: 1960 Evinrude 40 HP, mercury switch
Dual mercury switches are supposed to have two wires, plus a ground wire. If you don't have all three, the switch is shot.
Mercury switch #1 completes the ground return for the vacuum cut-out switch which prevents motor run-away under no-load conditons. But it only does that function at low throttle positions. That is what the mercury switch does. Otherwise, the vacuum switch can cause mis-firing at cruise throttle settings.
Mercury switch #2 completes the ground return from the starter solenoid pull-in coil. It's purpose is to prevent starting the motor at fast throttle settings and running over something or somebody. Send me a PM if you are interested in a new one. This switch is subject to instant wire burn-off if somebody tries to use a car solenoid.
  #3
Old August 15th, 2007, 01:55 PM
What are the pitfalls of disabling these switches, as one already has been?
  #4
Old August 15th, 2007, 02:25 PM
It looks as though switch one has been bypassed by a manual ground toggle switch connecting the cut-out switch to ground.
Being a switch activated by its level, I'm wondering if having my motor tilted slightly forward is having an effect on its operation. As the engine jiggles when it cranks it seems to also cut out.
  #5
Old August 15th, 2007, 06:26 PM
Somehow I got it to crank and fire and almost run but something in the magneto is scrubbing the flywheel. Doesn't sound good!
  #6
Old August 18th, 2007, 04:04 PM
spy1309 spy1309 is offline
Envirude_boater I have the same engine like yours and same year.
I was wondering about those mercury swiches to, I got a hang pretty much how they work, F_R gave you the best description.
There are 2 switches one has 2 wires on it and the other one only one wire and I dont understand how it works with only one given that the other contact ( metal body) is not attached to the ground or anything else.
I have problems stoping the motor from the ignition switch ...do you have any problem?
Also on my vacuum saftey switch I have two black wires connected to the main lead but the manual shows only one wire.
Can you please tell me how many wire you have attached to the vacuum safety switch? or can you send me a picture is pretty rare to find somebody with the same year engine and model, I can help you with some other questions if you need.
I just completed the coils, points and cindenser replacement if you need help let me know.
''It looks as though switch one has been bypassed by a manual ground toggle switch connecting the cut-out switch to ground."
The reason they did that is because the previous owner had the same problem like me he couldn t stop the motor from the ignition switch, as the last resort I will do the same but I suspect that is something wrong with the wireing at the mercury switches or atthe vacuum safety switch.
  #7
Old August 18th, 2007, 04:21 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
the base of the coil is probably rubbing the flywheel.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #8
Old August 18th, 2007, 05:17 PM
F_R F_R is offline
Spy, go to aomci.org. Go to Ask-A-Member forum. Scroll down to 8/14/07 thread titled 1960 Evinrude 40hp Wiring Hlep Wanted. Read the thread.
  #9
Old August 19th, 2007, 03:21 AM
F_R dude hat down you are one of the most helpful dude on this forum
LOL but still I don t get it F_R the electrical circuit was very helpful, I checked againt mine and is the same so pure and simple I see go diference or a misconected wire, now if there is no ground at the ignition switch how do you kill the engine? buy shorting the 2 M terminal ( in the ignition switch)? they are botg positive so I don t think it will work.
And the guy from the post you sent me has the same problem, the previous owner installed a kill switch for the same reason.
I start to take this problem personal so far nobody who had it solved it as far as I know
  #10
Old August 19th, 2007, 11:44 PM
I haven't got my engine running yet so I can't provide any help on stopping it. My two mercury switches were not grounded and only the second switch had a wire connected to it. The switches appear to have a metal tangs to fold over on the wires to hold them in place. When I clipped a jumper wire from the tangs to the engine ground, the engine cranked. I noticed that if I twisted the throttle control past "Start", it would not crank.
I think I have a new ignition installed since it has only three terminals, "BAT", "SOL" and "IGN". There was nothing connected to the "IGN" terminal.
  #11
Old August 20th, 2007, 09:17 AM
F_R F_R is offline
The two M terminals short together internally in the switch "off" position. That connects the two sets of magneto breaker points together, which kills the spark and stops the motor.
If you don't have two M trminals you don't have the correct switch. You have a battery ignition (car) switch. It will blow up a coil if you connect the IGN terminal to one of the black wires.
  #12
Old August 21st, 2007, 12:23 AM
Envirude _boater the help goes both ways if you need help with pictures or any info I will help you, my wireing is original so I can help you with that to if you need help.
  #13
Old August 21st, 2007, 10:10 AM
Thanks spy1309, I'm wondering why your motor doesn't turn off if your wiring is original. I have to ask, "How do you know it's original wiring and the original gas tank"?
I have to take the flywheel off to check what's rubbing. How did you hold your flywheel to loosen the nut?
  #14
Old August 21st, 2007, 02:06 PM
I took a channel lock opened it as wide as I got allowed,then I proped the half mouth edge of the plyer on the flywheel tooth and the arms of the plyer were resting against the thermostat housing for leverage, It got out nice and easy.
The tank has the year stamped on it and the Johnson instructions of how to and how much gas you have to mix plus the capacity of the tank in regular gallons and imperial gallons.
The wireing goes to junction box is easy to see that is the original one as insolation on the wire tell you that is discolored and is the original color plus the connections tarnished by the number of year they were in contact with the elements.
Be careful with the flywheel don t mess it up, if you have problems to remove it and you will don t force it.
If you encounter problems I will tell you the steps I did to come out nice and easy.
  #15
Old August 21st, 2007, 08:19 PM
Can I e-mail you directly? I have difficulty attaching photos to iboats. Besides I don't want to fill up iboats with our ramblings.
semenuk1@hotmail.com
  #16
Old August 25th, 2007, 03:51 PM
Quote:
I got the flywheel off and the rubbing problem was a tooth broken off the manual starter ratchet plate. The flywheel inspection hole cover is missing so a tooth fell in there and was hitting the perimeter of the ignition assembly. Luckily no damage that I can see. The rest of the teeth were found down in the bottom engine cover. Good thing I didn't get it running; it could have catastrophic.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1960 Mercury model #? turtle1173 Mercury & Mariner Outboards 5 November 9th, 2009 03:12 AM
1960 Mercury 200 22hp kramer9802 Mercury & Mariner Outboards 2 September 7th, 2008 04:40 PM
1960 Mercury Kiekhaefer 400 beavis331 Mercury & Mariner Outboards 4 October 3rd, 2006 12:39 PM
HELP!!! 1958-1960 Johnson Start Switch Connections What Colors/Where? crestliner Johnson & Evinrude Outboards 2 July 12th, 2003 03:49 PM
1960 Evinrude Vacuum cut-out switch Lark40 Johnson & Evinrude Outboards 12 April 2nd, 2002 05:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
