Just a couple more oddities to add on this motor shutting down.
1) After it shuts down, there is electricity to the horn, graph, etc.
2) There are no alarms going off prior to the motor shutting down.
3) The lights cycle through when the key is turned right after it shuts down, but will not crank over.
4) After its been running for awhile ( and hasn't shut down on its own) and the key is used to turn the motor off, it will not start back up again.
5) It takes about 5 to 6 minutes for the motor to start backup after it stops.
Hope this additional information helps and thanks in advance
Tr22
