  #1
Old August 14th, 2007, 09:41 PM
Big Papa Big Papa is offline
Question 70 hp Evinrude water in cylinder 3
Recently purchased a 1978 Sea Sprite with a 1978 70 hp Evinrude. Ran nice the first trip but noted that throttle response was slugglish from low idle to wide open. Would periodically die out when transitioning through this mid range speed. Any suggestions on this issue once I get the second bigger issue resolved noted below.
Second issue noted during second trip. Same symptoms as above but died out and couldn't get restarted. Pulled plugs and noted water in cyl #3. Turned it over an water misted out #3 plug hole. Checked compression on all 3 cylinders. All rock solid at 110 psig. Thinking head gasket at this point but havent opened it up to check the cylinder or head. Looking for some advise and confirmation Im on the right track. Is there anything that Im leaving out. Pretty new to the outboard thing, also wondering how difficult to tear this thing down. I would appreciate any help!!
  #2
Old August 15th, 2007, 11:25 PM
jtexas's Avatar
jtexas jtexas is offline
Default Re: 70 hp Evinrude water in cylinder 3
highly recommend the factory shop manual, available at kencook.com or marineengine.com - nothing tricky about the cylinder head.
Three fixed jets in the carbs. That engine will idle on two cylinders and sound perfectly happy doing so - till you put a load on it. If the head gasket don't fix your sluggishness, a carb rebuild will. Heck, might as well do it now anyway, they always seem happier with a good carb cleaning.
If you don't know when the water pump impeller was last changed, I'd do that now, too.
welcome to iboats!
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #3
Old August 16th, 2007, 08:20 AM
Thanks jtexas. The site is awesome. I was just looking into the manual locally here in Green Bay but will check out the sites you referenced. Good call on the carbs and I have been reading several recommendations on the impellar.
Another quick question. I have also been reading that the exhaust plate gasket could allow water into the cylinder. Does having good even compression on all cylinders around 110psig help differentiate between a cylinder head or exhaust plate gasket?
By the way, you described the idling fine then bogging scenerio perfectly. Confirms to me that this motor was never firing on all three. Thanks again bro
  #4
Old August 16th, 2007, 10:16 AM
F_R F_R is online now
Forget the carbs and everything else for right now. It is absolutely critical that you get that water leak fixed. It will destroy the bearings in the crankcase. If they aren't already. Rust happens to polished steel very quickly.
If it is not the head gasket it is the exhaust cover. Probably the exhaust cover. (Naturally, that is the hardest to get to!) Those inner covers will warp at the slightest bit of overheating, and then water squirts into the exhaust ports. There is lousy support for the cover around the ports. You have to replace the warped cover and gaskets.
  #5
Old August 16th, 2007, 01:50 PM
mikesea mikesea is offline
ditto with fr,the exhust plates were chronic problem causing omc to change in later yrs ,ther are multiple plates and gaskets,your comp is great ,leaving the head gasket to likely not be suspect,and you running issues may get better when water intrusion is dealt with,i suggest you also spray some oil in the cylinders for protection while you fix problem
  #6
Old August 16th, 2007, 04:24 PM
Thanks Mikesea and FR. Im on it. Going to tear into the exhaust gaskets next week and noticed this am that there are several...cover, a larger plate and smaller one. I will check for trueness when its opened up.
I sprayed some W-D 40 down the leaky cylinder. Will that do it for a week until I get to it or should I fog it with something else to prevent rusting.
Thanks for the comments.
  #7
Old August 16th, 2007, 05:00 PM
The rusting to be concerned about is in the crankcase. Putting oil in the cylinders won't get it down there. Best is to fog the heck out of it.
  #8
Old August 17th, 2007, 11:21 AM
Will do. Thanks for the heads up! Will post a success story soon....I hope.
  #9
Old September 6th, 2007, 10:34 AM
Hey guys. Just wanted to give you a quick update and thank everyone for the help. The exhaust plate gaskets were definately the problem. Big holes and lots of water in #3 and actually in #2. Im surprised this thing actually ran. I got curious at this point and pulled the head. Head gasket was in pretty rough shape as well. It had good compression by was leaking down pretty good. Took the kids out tubing over the Labor Day weekend and the old 70 ran like a top. Sooooo Im back in business. Thanks again. This site is awesome.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 Evinrude 175 water in 1 cylinder kekray13 Johnson & Evinrude Outboards 9 July 26th, 2007 09:08 PM
1984 Evinrude 140 - Water in cylinder hoeser Johnson & Evinrude Outboards 1 June 19th, 2006 03:57 PM
2002 Evinrude 225 water in cylinder Helomanic Johnson & Evinrude Outboards 1 May 26th, 2005 07:30 PM
72' 65 HP Evinrude has water in bottom cylinder downjigger Johnson & Evinrude Outboards 1 June 30th, 2003 11:50 AM
72 65hp Evinrude getting water in middle cylinder Catotonic Johnson & Evinrude Outboards 2 January 21st, 2002 04:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
