Re: Evinrude 65HP loss of WOT
classic symptom of clogged hi-speed jets. most common cause of clogged hi-speed jets: inactivity. motor sits for 2, 3, 4 months, gas turns to varnish. Next most common cause: contaminated fuel. Still using the original metal 6-gal tank came with the motor? it's probably got little particles of rust in it. You might want to try pumping the primer bulb while its bogging, if it improves performance, rebuild the fuel pump. But my money's on carbs.
But, first, check the compression - no since throwing money at a motor with bad compression.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
