115 johnson runs good then dies cant restart
jeffw51
1970 115 johnson starts easy ,runs good ,idles good ,runs out good then dies and is impossible to restart for several hours then it will run fine again until it dies again?please help
Barnacle_Bill
Re: 115 johnson runs good then dies cant restart
When its doing that again you need to check to see if it has spark to the plugs.
jeffw51
thank you for your response, I will check for spark next time it dies.Any ideas on what to do if i find no spark?
bigbob_FTW
Check coils to make sure they are not cracked, allowing spark to arc to the mounting flange. this is easiest to check at night.
