Evinrude 200 1998 Vindicator/ Carb/
If you are facing the carbs with the air silencer off
on the Intake where the reedvalves are located there are two fittings that come straight one is toward the bottom the other is a little higher.
What connects to these fittings one of mine had a plug on it the other went to the air box(silencer)
I'm not sure if these are routed correctly
