I have a elctro-hyd shift large gearbox johnson 1971 50hp.
Am trying to set throttle ,idle mix and timing. What is correct procedure? right now at idle timing is at about 2 deg after atdc. not sure on max as still want rest right before that. Throttle set to line and butterfly just starting to move. the link to cam is adjustable-- what should length be? ie... should idle be at the line on cam with roller lined up or will roller not be touching. Manual doesn't state such just says line up at marks so butterfly is just moving but doesn't say if this is idle position.
Thanks
Thanks
