chriswilliam
- Jul 20, 2007
- 3
Any Thoughts?
I have had this engine since new, ran great for 21 years. Then last July the lowest piston melted on me when I ran out of gas. Just before the engine died I heard a pop. Taking the engine apart the #4 piston (lowest) was melted on the intake side. I since rebuilt the engine and carbs. I "Broke" the rebuilt engine in as recommended by omc and at about 11 hours running time the samething happened. When running out of gas I heard a pop and the same piston had melted.
When rebuilding I put in the low compression head gaskets so I could run low octane fuel. I also checked the timing, replaced the thermostats, water pump, cleaned and rebuilt the carbs, verified the VRO was working, etc.
After rehoning this time so I would have a good surface to mic I noticed a small 1/4 inch crack in the sleeve starting at the head mating surface and proceding in the direction of piston movement.
Do you think this crack could cause the detonation? If some (very small amount) of water got into the cylinder? If not any thoughts why I burned the piston in the same cylinder again?
I plan to check fuel pressure when I get it back together.
Since the sleeve needs to be replaced any machine shop recommendations? prefer local to the Boston Area.
Thanks
Bill
Thanks
Bill
