  #1
Old August 13th, 2007, 10:11 PM
derose derose is offline
Default Help required for 1981 35hp Evinrude: impeller
Just bought a 1981 mint condition 35hp Evinrude long shaft with low hours. Hasn't been used for several years. How can I test the impeller to make sure it's in good shape. Can I run motor in a bucket? How long will it take for water to come out?
  #2
Old August 13th, 2007, 10:20 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: Help required for 1981 35hp Evinrude: impeller
Welcome derose!
Don't test.....just replace it. Setting for so long, the impeller has probably dried out and lost it's memory. May pump for a while but will surely fail soon.
If you run it after replaceing the impeller, run it in a garbage can full of water and make sure the water level is above the mating line between the lower unit and mid section.....these pumps don't draft water real good and should be submerged to operate correctly. OR.....run the engine of "muffs" and a water hose. Just remember not to over rev the engine.
Either way, water should appear from the tell tale in a second or two.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old August 13th, 2007, 10:22 PM
HighTrim's Avatar
HighTrim HighTrim is offline
If the age of the impellor is unknown, best to change it for peace of mind. Its a cheap thing to change, expensive thing to have go on you, and anyone the fairly mechanically inclined with a basic tool kit can do it. Do you have a manual? If not, you should get one. Bucket wont be enough, best way is a barrel or large garbage can filled with water for testing. Can also use "muffs", but I am unsure if you year allows it, hopefully someone will jump in and let us know. Muffs are simply 2 rubber plungers that a hose attaches to that you place over your water intake to send cooling water to the impellor which sends it to the motor.
__________________
Chris
  #4
Old August 13th, 2007, 10:23 PM
HighTrim's Avatar
He types faster than me
__________________
Chris
  #5
Old August 13th, 2007, 10:26 PM
Well this is great news guys, thanks for the quick response. I feel better as I'm told that there is only abut 30 hours on this motor and I was hoping it would not be something serious. I will pull out the manual and see if I can do it myself, I am a little mechanically inclined.
  #6
OBJ's Avatar
OBJ OBJ is offline
That's OK HighTrim....we're both on the same page....:-)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1981 evinrude 35hp dry weight? redfordjeff Johnson & Evinrude Outboards 3 April 9th, 2007 08:58 PM
1981 35hp evinrude lower gear ratio? merc 18xd Non-Repair Outboard Discussions 1 February 3rd, 2007 12:56 AM
1981 Evinrude 35hp compression merc 18xd Non-Repair Outboard Discussions 2 January 30th, 2007 01:23 PM
1981 Johnson 35hp and 1984 Evinrude 20 hp piscesplaypen Johnson & Evinrude Outboards 7 June 9th, 2004 09:28 PM
1981 35HP EVINRUDE LOWER UNIT river5 Johnson & Evinrude Outboards 0 July 9th, 2003 06:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
