Re: sea foam?
I'll Just add that sea foam is essential in two-stroke motors as a cleaner/stabilizer. It's a must for keeping engines as well as their fuel systems clean of carbon, varnish and such. It works great in any kind of motor-I use it on everything from the weed whip to the jeep. Pour a can of it all at once into the intake of a warmed-up car motor and kill it the moment the can is gone-let it sit for 15 minutes and start it up. You'll be amazed at the amount of black and grey smoke that comes out! The sea foam makes alot of it's own smoke, but that smoke is white. The other stuff is all the garbage burning off your valves, pistons, and anything else in or near the combustion chamber that accumulates carbon. Will eliminate ticks, knocking and pinging from detonation due to carbon hot spots. I could go on and on about this stuff, but I'll spare you guys-just use it-it's good stuff!
