  #1
Old August 13th, 2007, 08:23 PM
falconduvent falconduvent is offline
Send a message via AIM to falconduvent
Unhappy 1976 Evinrude 25 starting problems
i have a 1976 Evinrude 25 that is under the weather.
First it ran, then after a few days, it carboned up on me.
Cleaned plugs, to no avail.
Discovered that oil gas ratio was supposed to be 50:1 instead of 32:1, so fixed that.
Cleaned the carb and it ran fine again, took it out, after 10 minutes wide open, began to hesitate and slow, by the time i got back to the dock, it was shaking and coughing. the #1 plug was badly carboned and the #2 plug was fine. Cleaned the plugs and tried again, didnt start, tested spark, found the #2 plag was shot. Looked up spark plug advice, found out i had the wrong plugs, rplaced them with the right ones, J4C @.030 from champion. Tried it again, engine coughs, take off choke, it wont start, floods. Any suggestions?
  #2
Old August 13th, 2007, 09:30 PM
wbeaton's Avatar
wbeaton wbeaton is offline
Default Re: 1976 Evinrude 25 starting problems
Are you getting spark in both cylinders? Have you cleaned and set the points (.020")?
  #3
Old August 13th, 2007, 09:40 PM
Solittle Solittle is offline
Did you rebuild the carb?
  #4
Old August 14th, 2007, 09:19 AM
I have a fat blue spark on both cylinders, points set at .030, as recommended by Evinrude. The carb is in excellent condition, and was overhauled and cleanded 2 days ago. The low speed jets, (there are 3) were slightly obstructed and the main jet was blocked. Now it doesnt start because it floods right off the bat. The motor ran fine up untill a few days ago.
  #5
Old August 14th, 2007, 10:12 AM
wbeaton's Avatar
Plug gap is .030. The point gap is .020.
If its flooding you still have a carb problem. Did you rebuild the carb or just clean it? Sounds like either the float needle isn't seating or the float is sinking or is not set correctly. Buy a rebuild kit if you didn't the first time and clean everything again.
  #6
Old August 14th, 2007, 10:22 AM
BoatBuoy BoatBuoy is offline
Since one plug fouled and the other one didn't, it sounds like maybe your fuel pump is leaking fuel into the cylinder where it's mounted. Pull the pump off and squeeze the primer bulb on the fuel line and see if fuel comes out the back of the pump.
  #7
Old August 14th, 2007, 01:47 PM
fixed it. The final issue was that when i put the carb back onto the engine, i neglected to turn the needle valve for the low speed jets in the proper amount. I compared it to a working motor like mine and adjusted it accordingly. when i tried starting it again, it took a little adjusting while rnning to find the sweet spot between too rich and too lean. i disconnected the control nob for the valve so it will not be in danger of accidental maladjustment. Thanks for your insight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1976 115hp johnson starting problems. flech01 Johnson & Evinrude Outboards 11 July 7th, 2006 08:25 AM
115 Evinrude 1976 starting problem!! boofberry Johnson & Evinrude Outboards 4 February 18th, 2006 07:03 AM
1976 Evinrude 85hp Very Hard Starting timrauch Johnson & Evinrude Outboards 3 May 20th, 2005 08:40 PM
Mercury 1150 (inline 6 115hp 1976) starting and power problems isoaga Mercury & Mariner Outboards 3 March 28th, 2005 06:25 AM
1976 135hp Evinrude V4 starting problems woolly bugger Johnson & Evinrude Outboards 1 September 9th, 2004 09:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
