  #1
Old August 13th, 2007, 07:22 PM
boatyug boatyug is offline
Default Help with a NO OIL LIGHT on a 2000 Evinrude Ficht 150
Hi there...
Ive exhausted all of my back yard "know how" and I cant bear to bring my motor to the stealer oops, I mean the Dealer to solve my "NO OIL LIGHT" that comes on problem...I hope someone here can help!
I have a 2000, Evinrude FICHT 150Hp with about 600 hours on it. While out this past weekend and after some high speed running and a few miles of trolling out at Cape Cod, we were on our way into Pamet harbor when the "No oil light" suddenly came on with that ear piercing tone....Anyway, I have plenty of RAM oil in the tank (2gals) and the primer bulb was hard. We shut the motor down and restarted. The light and tone were gone and things appeared back to normal. I figured that this was a fluke so I went back out into the bay, buzzed around at high and low speeds and decided it was "fixed". Again, back into port (while going about 3knts) and the light and tone came back. I shut the motor off, turned it back on again and the light and tone were now off. We put the it on the trailer and called it a bad day.
Next day, at the lake, the light and noise came on about 2 times only while at very slow speeds.
HERES WHAT I HAVE DONE SO FAR:
I cleaned and inspected the oil pressure switch..looks fine, clean and no corrosion. (oh, also I have already ordered a new one for only 23$ I figure I should start there)
I have verified that the return oil line to the reservoir was flowing at an adequate rate of flow while the motor was at 1500rpm say 12oz or so per min.
I have removed and verified that all of the oil lines on the oil distribution manifold (just above the electric oil pump that looks like a fuel injector pump) are squirting oil at an adequate level as well.
I have tested oil pressure by screwing a mechanical oil pressure tester into the same hole that the oil pressure sender switch occupies. I found this motor to have CONSISTENT 12psi when at startup, idle and out to about 2800rpms. It goes up a bit after 2800 but I dont want to run this motor WOT on a garden hose...lol.
Heres what the local stealers have told me: "needs an oil pump" "needs an oil pump diaphram" "you need a new tachometer" "needs an oil pressure sending switch" "aw, thats just a FICHT being a FICHT" on and on and on...
Should any of you have a suggestions PLEASE let me know and that would be most appreciated!!!!!!!!!
  #2
Old August 14th, 2007, 01:58 AM
luckyinkentucky luckyinkentucky is offline
Default Re: Help with a NO OIL LIGHT on a 2000 Evinrude Ficht 150
Was it a constant tone or variable chirp? I've heard about instances where the engine sends out the wrong signal, but the warning sensor picks it up right. For instance your check oil light might be on, but if it's a constant tone like a fire alarm then you have a fuel related or overheating issue. Boat builders make common wiring mistakes all of the time.
For instance, my 95 Skeeter 200SL had an issue with the warning horn going off when I would turn on the aerator! Come to find out some Nit Wit at the factory wired the aerator pump to the Nav light switch on the boat, and everytime I would turn on the aerator it would overload the switch and cause a short. After talking to a few Skeeter owners over the net I found out it was a problem with several boats produced within a 2 month period of each other. It was just some idiot at the factory that didn't pay attention. If you could describe the tone in more detail it would be great!
  #3
Old August 14th, 2007, 02:42 AM
noelm noelm is offline
more than likely it is the "no oil sensor" pretty common to have an intermittant fault with them, I have seen a few now, very easy to replace to test it, and not very expensive, but if in doubt take it to your local stealer!
  #4
Old August 14th, 2007, 08:41 AM
Exclamation Re: Help with a NO OIL LIGHT on a 2000 Evinrude Ficht 150
Thanks...both equally good suggestions.
I have ordered and plan on replacing the oil pressure sensor (sender) switch. Its going to be here on Thursday and cost just about 25$. It was the least expensive part in this entire oil assembly.
As for the tone and light, the tone was a constant BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEEP that would not cease until I put the key into the run position; the red no oil light was constantly illuminated and also would not go away until I shut the motor down. I have been plagued by many broken water pumps on this motor and know exactly what the computer, lights, noises and motors responses are to an overheat condition.
Trust me, this new "no oil" light situation is much different.
I got my hands on a shop repair manual last night and it stated that this sensor is set at 4psi and wont send a signal until the oil psi stays below 4psi for quite some time. With that mechanical gauge reading I took yesterday, Im still bettting on the sensor and PRAYING its not the oil injector pump at a mere $660.00
  #5
Old August 14th, 2007, 11:51 AM
I seriously doubt it has anything to do with your oil.
I had the Exact same thing happen to me in the situation described above. /\ /\ /\
Actually that tone is a Fuel restriction warning or overheat warning depending on the circumstances. Here are the instances where you hear a horn, and the descriptions.
Overheat = Continuous tone similar to a fire alarm in your home.
No Oil = continuous short tones
Low Oil = chirp every 40 seconds
Fuel restriction = Continuous tone at or near full throttle.
I would check out all of the possibilities, and then start testing switches. Chances are you have an electrical problem. It's easy to throw money at a problem that seems evident, but when you get to the end of it nothing has been fixed. It's funny they don't mention "electrical issues" in our manuals as they account for 50% of us replacing parts in error.
  #6
Old August 14th, 2007, 07:44 PM
seahorse5 seahorse5 is offline
luckyinkentucky,
What you posted does NOT apply to motors 1996 and later!
  #7
Old August 14th, 2007, 08:16 PM
Thumbs down Re: Help with a NO OIL LIGHT on a 2000 Evinrude Ficht 150
Well....
Since people seem to think that my motor is overheating let me start by saying I have a brand new Evinrude water pump impeller housing and "entire top half" of the pump installed. This pump is approximately 1 month old and has about 25 hours on it. This pump is changed every year by myself. The tell tale water squirt is exceptional and is perfect for this season. I have owned this motor for 7 years, installed 7 water pumps and know when ones on the way out or when its already broken (no tell tale, poor tell tale, hot light on tach comes on with the incessant beep etc). With that being said, lets agree that this is NOT a cooling issue at this time. If it were, the motor would be warmer then usual, the motor would have gone into S.L.O.W. mode and the tell tale would be squirting warm water which it is not. Also, I would not be able to do high speed runs (and have no light come on). As it seems that the NO OIL light and tone only come on at slow, (under 5knts) operation.
  #8
Old September 3rd, 2007, 11:59 AM
Quote:
Originally Posted by boatyug View Post
Well....
any more thoughts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Year 2000 225 Evinrude Ficht No Oil light doug brander Johnson & Evinrude Outboards 3 August 14th, 2007 08:51 AM
2000 Evinrude 225 Ficht kelly holmes Johnson & Evinrude Outboards 3 May 23rd, 2006 07:33 PM
2000 225hp evinrude ficht fuel starvation? no ck eng light slcstein@comcast.net Johnson & Evinrude Outboards 11 February 25th, 2006 03:04 AM
2000 175 Evinrude FICHT MokieB Johnson & Evinrude Outboards 2 November 6th, 2005 07:24 AM
2000 Evinrude 175 ficht boatfever Johnson & Evinrude Outboards 3 August 2nd, 2005 10:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
