  #1
Old August 13th, 2007, 12:48 AM
arima arima is offline
Default 2005 Yamaha 150 4 Stoke Died Wont Fire Back Up
I Have A 2005 Yamaha 150 Four Stoke That I Bought New In November And I Was Out Fishing The Other Day And It Felt Like It Just Ran Out Of Gas And Died I Thought Dam Bad Gas So Went Back To Port On Port Motor And Changed The Fuel Water Seperator There Was No Water But Changed Anyway Then I Changed The Fuel Filter On The Front Of The Motor...after That I Changed The Plugs And Checked For Spark I Have Spark The Fuel Water Seperator Is Primed But It Wont Fire Up Can You Guys Please Help Me..this Is Driving Me Nut!!!do You Think It Could Be Fuel Pump?the Other Motor Runs Perfect I Cant Figure It Our..
Mike
  #2
Old August 13th, 2007, 02:18 AM
bowhuntrrl bowhuntrrl is offline
Default Re: 2005 Yamaha 150 4 Stoke Died Wont Fire Back Up
Take it in for warranty work, why struggle with it ?? Sounds like you've made a reasonable attempt to fix it. can you pull the fuel line off the output side of the pump ??? That should pretty much answer that question.
  #3
Old August 13th, 2007, 06:40 AM
rodbolt rodbolt is offline
if no water is presant and you have spark I will go out on a limb and say you either lost fuel pressure or the VST filter is clogged. in either case a trip to the dealer will be in order.
hopefully something simple and covered by warrenty.
while pump failures are rare they do occur as do fuse failures.
relays fail as well.
its all rare but it does happen.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 80 hp 2 stoke outboard Jimha Yamaha & Suzuki Outboards 2 January 14th, 2007 02:28 PM
yamaha 4hp 4 stoke... Anyone got one? jake069 Yamaha & Suzuki Outboards 1 August 8th, 2006 09:52 AM
Hit Sandbar and Engine Died, woulldn't start back up DSmithZ28 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 June 21st, 2006 11:59 AM
yamaha 115 four stoke khwannam Yamaha & Suzuki Outboards 19 August 27th, 2004 03:21 PM
Yamaha 90 Four Stoke - any known problems? yamahamaninmobileal89 Yamaha & Suzuki Outboards 2 March 27th, 2003 01:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
