August 13th, 2007, 12:36 AM
How to wire a Tachometer Mercury 1965
Help again:
Have a 1973 Larson boat, The motor has been changed, it has a Mercury 1000, 100 HP, the boat has a tachometer but it isn't hooked up. Years ago I knew how to wire thes things up but have forgot where the wires go on the motor on one this old. Thanks for any help.
August 13th, 2007, 12:54 AM
Re: How to wire a Tachometer Mercury 1965
as long as the tach is set up for that motor or has adjustable pole settings your ok. run a wire from either yellow wires that hook up to the rectifyer on the motor.
August 13th, 2007, 01:00 AM
I'm not sure if it is or not, the boat is a 1973, someone replace the motor with a 1965 Mercury 1000 100 hp, I will check and see, Thanks for your fast answer.
Bill
August 13th, 2007, 01:02 AM
most of the aftermarket tachs are adjustable. you can search their sites for instruction manuals for specific wiring
August 13th, 2007, 01:05 AM
Will do, again Thanks.
August 13th, 2007, 06:21 AM
The old style tachs were ignition driven and the new style tachs are alternator driven.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
August 13th, 2007, 06:34 AM
Quote:
Originally Posted by
ricksrster
This is the old style tach, do you know where on the ignition I should run a wire?
August 13th, 2007, 12:21 PM
find the make and model number of the tach. if its a quicksilver, some models were engine specific
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
