Help
I have a 1998 200HP Evinrude Vindicator I had the powerhead Rebuilt and am installing it my self. My question is I have a Rubber line the same size as the fuel lines from the fuel rail to the carbs. On this line is a check valve. The picture I attached shows #(42) the checkvalve=line in question. I'm not sure if the location of this was correct when I tore down the motor.The P/H has been removed before not by me. This line and check valve was routed to one of the small fittings on the Intake Manifold under the carbs up to the top fitting on the intake manifold under the carbs. These fittings are 90 degree plastic fittings and there are a couple on the Intake Manifold. I believe these fittings are part of the OIL Scavange System that recirculates the excess oil and fuel that accumilates in the crankcase. Does not make sense to me why a line with a check valve goes from one fitting to another fitting on the intake
which is basically the same thing. I think this may be located incorrectly when I disassembled motor. I have a manual but does not showing routing of this.Does anyone know what this is and where it is routed.
