  #1
Old August 12th, 2007, 09:33 PM
jwilkey84 jwilkey84 is offline
Default 75 evinrude carb and pee hole question
I am working on a 75 40hp evinrude. I took the carb off and gave it a good cleaning, but didn't install a kit because the marina that told me they had one didn't, but the mechanic looked it over and said just to put it back together try it. Well I tried it and it is getting flooded really bad. It will run for a few seconds and then it dies and gas comes pouring out of the front of the carb. I did notice when I was putting it back together that the needle valve wouldn't always come down when the float would. About half of the time it would. Would that be causing this problem? Also, there are two holes in the back of the motor that are fairly close together, are these for water of exhaust or both. For the few seconds I had it running, there was no water coming out of these holes, but I didn't know if that was just for exhaust.
  #2
Old August 12th, 2007, 10:29 PM
spy1309 spy1309 is offline
Default Re: 75 evinrude carb and pee hole question
The needle has to work 100% of the time not 50 not 75 ...100% and the reason is that the needle allows the gas to enter the bowl when gas level is low or stop the flow when is full.
It looks like your needle does not stop the gas to overflow the bowl hence the flooded engine.
Also I don t know your carburator my 40hp is 1960 but the main jet has a smal rubber gasket where it mates with the carburator bowl, alot of people mistakes that gasket with gunk and they remove it.....the side efect is flooded engine and or running very rich no matter the jet setting.
There has to be a carburator kit , if they have one for my 1960 motor for sure there is one for yours.....ok i took a look here is your carburator rebuild kit....http://www.iboats.com/mall/partfinde...****=123670030
Copy and paste in your browser it will take you to the page where you can order to.
  #3
Old August 13th, 2007, 12:29 AM
my needle valve is stuck shut. Wouldn't that stop the flow of gas from even getting to the bowl? Or am I totally backwards?
  #4
Old August 13th, 2007, 12:40 AM
reload reload is offline
Your thinking is correct. But what you don't know is if the neddle is stuck in the up position, is it really closed or just stuck in crap preventing it from moving open or closed. I would suspect the problem being there. There should be a little tang that pulls the needle open when the float falls. As far as the holes you are refering to, after just a few seconds the thermostat would not even be open. Those holes a re the holes for exhaust and water to escape if there is insufficent draw out the prop (or back pressure preventing the exhaust escaping). Normally there would be very little water or exhaust coming from those holes.
  #5
Old August 13th, 2007, 09:02 AM
On this particular carb there is nothing physically linking the needle valve to the float, it simply falls from gravity as the float falls. And I am positive there is no gunk in there as I just got done cleaning it. I will just get a kit for it and try that out. As for the pee hole thing, I didnt know if this motor had a thermostat or not. So how much water should come out normally and how long should it take to get the engine hot enought to activate the thermostat?
  #6
Old August 13th, 2007, 09:13 AM
F_R F_R is offline
OK, the early float valves had metal needles. Then they went to soft tip needles, but being soft they would stick up in the seat. So now they put a little spring clip on the needle to drag it off the seat when the float drops. I don't know which one you have (except it isn't the one with the clip). Don't matter, it isnt sealing when it is closed. Get a kit and do it right.
Now, about that thermostat. There should always be some water sparaying out the holes in the back, whether the thermostat is open or closed. Takes maybe 5 seconds to fill the system, then there should be a spray. The amount of spray may vary according to conditions, but there should never be none at all.
Are you running it on a boat, in a bucket, or muffs or what?
  #7
Old August 13th, 2007, 09:24 AM
I am running it in a bucket. And the needle valve has the rubber tip, but nothing to drag it down, so I'll do it right. Thanks for the heldp
  #8
Old August 13th, 2007, 09:43 AM
F_R F_R is offline
And get it out of that bucket. That's probably why you don't have any cooling water. The water pump has to be submerged in order to pick up water.
  #9
Old August 13th, 2007, 10:23 AM
F_R, I haven't came across one of the metal needles in so long I almost forget they existed.
  #10
Old August 13th, 2007, 01:33 PM
clemsonfor clemsonfor is offline
I have seen some rubber tipped needles that did not have the groove for the spring clip or the clip to pull them down!
-Nate
  #11
Old August 13th, 2007, 04:32 PM
I thought it was submerged when it was in the bucket. The impeller is in the lower unit, right? It should be submerged, it is in a pretty deep bucket
  #12
Old August 13th, 2007, 08:46 PM
Alright, I just installed the new carb kit that did come with a new needle valve and a clip. I'll see how things work out!
  #13
Old August 13th, 2007, 09:07 PM
Everything works great! Runs great and also started spitting water after about 10 seconds. The only problem is that the water it spits out is really hot to the touch. I mean it is like hot dish water. I felt the block and it is also hot. I could hold my hand on it for 3-4 seconds but I only had the motor running for about 30 seconds which makes me think that it is just going to get hotter after time, so I shut her down and came straight to the experts. Did I just not let it run long enough? Could the thermostat be bad? I don't even know where the thermostat is. Just because there is water coming out the back of the motor doesnt mean that it is actually passing through the block, right?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
74 Evinrude Carb Question alumacraft74 Johnson & Evinrude Outboards 10 July 26th, 2007 10:54 AM
'94 evinrude 120 carb question SawBum Johnson & Evinrude Outboards 3 July 12th, 2007 04:25 PM
1995 130 evinrude carb question okam Johnson & Evinrude Outboards 4 October 15th, 2006 12:39 PM
1964 evinrude carb question 64_glass_magic Johnson & Evinrude Outboards 0 June 20th, 2006 11:15 PM
Tell Tale Hole Question (Pee Hole) Ikeasaurus Rex Non-Repair Outboard Discussions 3 August 21st, 2005 02:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
