  #1
Old August 12th, 2007, 08:28 PM
freddyray21 freddyray21 is offline
Default Mercury Comet KF 3 impeller questions
Got a question for the knowledgeable. According to the plate on a motor I just picked up last night it is a Mercury Comet KF-3 3.6 hp with a serial number of 359749. But according to http://www.oldmercs.com/models.html A KF-3 is a 3.5 horse and that serial number doesn't match. I just want to know so I can get the right parts. The motor has 130lbs compression dry. Of course it has no spark, but it seems none of these motors I pick up do. I think it will be a good little runner.
Last edited by freddyray21 : August 14th, 2007 at 11:06 AM. Reason: alter topic to fit new question
  #2
Old August 12th, 2007, 09:03 PM
tmcalavy tmcalavy is offline
Default Re: Mercury Comet KF 3
A KF-3 is a 49 Comet rated at 3.5 hp, so there may not be an official serial number record to compare it to. Pull the flywheel, clean the points, inspect the coils, wires, condensors and connections. I bet you get spark back unless the coils are toast and they may be. If they're cracked, delaminated you'll have to replace them. Also check the LU grease level, Lubriplate 105, and be prepared to shut it down on the first run in the barrel/tub if the water pump/impeller aren't working. Good little motors...I'm fond of the even earlier 1 cyl. Merc's and Wizards with the Buck Rogers look.
  #3
Old August 12th, 2007, 10:01 PM
that's what I got too, but the plate clearly states 3.6 hp. I figure to pull the flywheel maybe tomorrow to see.
  #4
Old August 12th, 2007, 10:23 PM
diaric's Avatar
diaric diaric is offline
found another site that lists the previous year, at 3.6 ke-5 comet deluxe. so there coulda been some parts cross over
http://www.infoblvd.net/sah/40-59_merc_model.html
  #5
Old August 13th, 2007, 01:36 AM
Scaaty's Avatar
Scaaty Scaaty is offline
Take it to the masters...post in "ask a member"...you will be SWAMPED with info
http://www.aomci.org/aomc.htm
  #6
Old August 13th, 2007, 03:33 PM
pulled the flwheel and cleaned the points and I have spark. Does anyone know what the gap is. I am assuming .020? It started on the first pull though it will need a carb float and impeller. I have them on order. Also it seems as if there is a lower cowling missing and the front of the carb has two screw holes. I am guessing the choke would be there.
  #7
Old August 13th, 2007, 03:46 PM
diaric's Avatar
champion j7j @ .025
  #8
Old August 13th, 2007, 04:20 PM
Actually I was asking about the points. The plug is a Champion J8C though
  #9
Old August 13th, 2007, 04:36 PM
diaric's Avatar
points, .018. manual says j7j for plugs but i see a champion site lists j8c for all old ones to 1959.
  #10
Old August 13th, 2007, 04:39 PM
diaric's Avatar
update, they don't stock the j7j anymore and have the j8c as replacement
  #11
Old August 13th, 2007, 04:46 PM
thanks. I have ordered an impellar for it, but am curious as the shaft does not have the tell tale round spot in it for the impeller. I am assuming it is in the lower unit at the top. I don't have a manual so would appreciate any instructions on how to do this one. I have done several in the past but all Evinrudes or Mercruisers.
  #12
Old August 13th, 2007, 05:09 PM
diaric's Avatar
some of the old ones are behind the props. this shows schematic of yours
http://www.crowleymarine.com/mercury_parts/1713/160.cfm
  #13
Old August 13th, 2007, 05:15 PM
looks interesting. I think I will need a manual for it. I found one but they want 50 bucks for it.
  #14
Old August 13th, 2007, 05:19 PM
diaric's Avatar
its cheap investment, 1/2 hour of shop time . old stuff like that, few who have expierence to answer a lot of questions
  #15
Old August 13th, 2007, 07:05 PM
Laddies Laddies is offline
It's quite a simple job here a picture break down
  #16
Old August 14th, 2007, 12:15 AM
thanks. That is most helpful.
  #17
Old August 14th, 2007, 11:24 AM
Default Re: Mercury Comet KF 3 impeller questions
Okay so I took mine apart and it doesn't look like the picture above. I pull the pin off of the cone, unscrewed the cone. pulled the prop off and mine has the water pump cover that screws into the housing (left hand threads found out the hard way. jb weld in order) then the impellar. The thing is I cannot see how it gets water into the impeller. Unless it is through the little holes pictured. the little holes look like they fit a spanner wrench though.
  #18
Old August 14th, 2007, 11:43 AM
okay by squirting pb blaster in the hole I found out where the water goes. Doesn't seem like much passageway, but it's not blocked.
  #19
Old August 14th, 2007, 02:34 PM
That picture looks like a quicky lower unit from the water pump cartridge. if it is and the left hand treads aiso sound like a quicky, you have a rare bird indeed the quicky were built for the KG4H and KG7H engines and not for that powerhead can you send a side view of the unit and another of the whole engine please
  #20
Old August 15th, 2007, 02:39 AM
http://www.fiberglassics.com/forms/f...messageID=5386
Here are pics of the motor. It is hard to say what has been done to the motor over the years. I am only going off the serial number and information off the cowl to verify what the motor is. I do know it has good compression and after cleaning the points it started on the first pull. I have ordered parts, but now wonder if they are the right ones.
  #21
Old August 15th, 2007, 02:54 AM
diaric's Avatar
the picture laddies sent doesn't look like yours, don't see a water intake in front of your prop. the drawing link i sent looks similiar, and shows the impeller inside the leg. how it all comes apart is a different story
  #22
Old August 15th, 2007, 03:13 AM
the link you sent seems to indicate it is in the leg, but in any event I don't have all the parts in the pic you sent either and no room to put them if someone had left them out. Figures I would have the oddball one.
  #23
Old August 15th, 2007, 09:31 AM
Thats a early unit for the KF 3, I ad to dig out a 1955 parts and service manual to get this picture, the assembly is done just like the Quicky lower unit so you don't need to pull the w/pump cartridge, the imp. goes in it and is covered by the nut,
  #24
Old August 15th, 2007, 10:53 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Laddies is right. Mercury used essentially the same design on all their direct-drive motors, locating the impeller on the propshaft.
If you should ever need to remove the waterpump cartridge - it pulls out, it is not threaded. Those two holes are for a puller. I find it easier to just pull out the propshaft, which brings the waterpump cartridge with it...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #25
Old August 15th, 2007, 11:12 AM
thanks to all.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Comet 3.6 KF-3 RatMan Mercury & Mariner Outboards 1 July 13th, 2005 04:34 PM
an WHY are we ******* with this comet, anyway..?? crab bait Dockside Chat 47 July 6th, 2005 08:43 PM
old mercury comet jcpicarella Mercury & Mariner Outboards 2 May 24th, 2003 09:32 AM
Mercury motor(Comet lighting) earl2359 Mercury & Mariner Outboards 3 June 23rd, 2002 07:26 PM
Mercury 7.5 Comet sarmajor Mercury & Mariner Outboards 4 December 29th, 2001 06:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
