  #1
Old August 11th, 2007, 10:16 PM
v20belowme v20belowme is offline
Default 1990 evinrude 200 hp shift shaft questions
hello i need help please,i do not have a manual yet for it and have been trying to search it here already but have not had luck.....how many turns out is the correct adjustment for shift shaft? also what are the tricks to putting up the lower unit,should it be in F,N,R ? when i get the lower unit up the shift shaft turns on its own and i still have a inch or so to go but it keeps getting caught up?? any help will be greatly appreciated
  #2
Old August 11th, 2007, 10:29 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 1990 evinrude 200 hp shift shaft questions
Sorry I dont have a manual, but I know when you find someone that does they will need to know if you have a short shaft or long, the tolerances are different on them. Grease the splines on the drive shaft before putting it up, remove the prop, if you havent already, and be careful not to bend the shift shaft. 2 ppl is always better than 1. The hardest part is hooking the shift shaft back up. If its spinning that freely, try just putting a dab of marine grease against the edge, may be enough to hold it until you slide it up. JMake sure the rubber grommet on the impeller housing fits nicely over the water tube as well while you slide it up, dont want that grommet blocking water flow.
__________________
Chris
  #3
Old August 11th, 2007, 10:38 PM
thanks for thereply its a 25 '' shaft and ive greased the heck out of it and it still doesnt go up..
  #4
Old August 12th, 2007, 12:04 PM
anyone have any idea for shift shaft adjustment on long and short shaft?
  #5
Old August 12th, 2007, 12:17 PM
Molaker Molaker is offline
I'm only going by my Seloc manual, so for what it's worth...
1978 and up 200hp - short shaft - 21.94" (55.48cm)
For the 25" long shaft add exactly 5" to the above.
The measurement is made "from the top of the lower unit housing to the center of the hole in the shift rod".
  #6
Old August 12th, 2007, 09:46 PM
thanks alot i will give that a shot.
  #7
Old August 14th, 2007, 10:29 PM
MOLAKER is that measurement taken with the shaft in foward neutral or reverse and when you say the lower unit housing where exactly do yopu mean?thanks in advance
  #8
Old August 15th, 2007, 12:46 AM
Quote:
The measurement is taken in Neutral. With the lower unit pulled, the measurement is taken from the top of the lower unit (the exposed edge that mates with the bottom of the exhaust housing) to the center of the shift rod hole at the top. Use something like a yardstick with a 90* cross piece to slide up and down to establish the distance parallel with the shift rod.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
shift rod disconnect on 88 hp 1990 Evinrude Herb Ruschmann Johnson & Evinrude Outboards 9 September 29th, 2006 12:21 AM
1990 Evinrude XP 175 Questions.. StratMan290FS Johnson & Evinrude Outboards 1 May 5th, 2006 02:47 AM
1990 evinrude 150 25" shaft boot gvisko Johnson & Evinrude Outboards 16 September 17th, 2002 07:39 PM
Evinrude V4 140 HP 1990 Warning Alarm Questions and Other Questions. Version 8 Pannet Johnson & Evinrude Outboards 17 March 5th, 2002 07:42 AM
Evinrude 140 V4 Yr 1990 questions Pannet Johnson & Evinrude Outboards 2 February 26th, 2002 05:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
