This is site is awesome.
I was given a 7 HP Sears Outboard Motor that was simply forgotten over time.
Followed the advice from other posts and went in to Sears website and got the following information.
Brand: Craftsman
Model #: 271-58531
Serial #: LO4825
On the motor I see the following:
7 HP
Solid State Ignition
Clutch Shift
Air-Cooled
Sparkplug - J8C Champion
On the cover it says:
Use 1/2 pint of SAE 30 or 40 outboard oil per (1) gallon of regular grade gasoline.
My question(s):
1. Can you tell me what year this is from?
2. Is the gas/oil ratio mentioned above what you would recommend with so many changes in gas and oil nowadays?
3. What type of oil should I use with this? chainsaw? 2 cycle oil?
4. This is the first motor I have ever owned, but want to learn more about outboard motors. I'm illiterate when it comes to any type of motor, but I figured I couldn't break it. Is this motor worth my time? Would you mind going through some of the steps I should do to try and bring this back to life?
Thank you in advance for your help
DA
Brand: Craftsman
Model #: 271-58531
Serial #: LO4825
7 HP
Clutch Shift
Air-Cooled
My question(s):
DA
