  #1
Old August 10th, 2007, 07:27 PM
newbie38 newbie38 is offline
Default 1998 Mercury 40 hp outboard convert from pull to elec. start?
I just bought a 1998 Mercury 40 hp outboard (serial # 0G660803, model 40M?) that is currently pull start only. I want to convert to elec. start as economically as possible. I know Mercury sells a conversion kit for about $400, but since I bought the motor for $1100 can't really justify spending that. It seems to me that if I get a starter, solenoid, and push button start, it should be a pretty straightforward prospect to do. Am I correct? Is that model already set for for charging system (I assume not)? If not, I would be ok with running the starter with no recharge setup, recognizing that I will need to regularly charge the battery. I should add that the existing motor already has the flywheel setup for accepting the starter.
Any help/tips you could give would be helpful. Also, does anyone have any suggestions for where to pick up used parts for this model? Thanks!
  #2
Old August 10th, 2007, 08:30 PM
Laddies Laddies is offline
Default Re: 1998 Mercury 40 hp outboard convert from pull to elec. start?
I believe your stator has alternator windings, it would be a good idea if you went here www.mercruiserparts.com the parts you need singlely before making a deciding what you are going to do. That engine is pretty new to find a doner engine for parts and you may be able to find a rebuilt starter but when you figure the solinoid,rectifier,switch,primer and wiring the $400 may not look so bad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Can I convert a pull start to electric? SliderM72 Yamaha & Suzuki Outboards 4 June 30th, 2005 05:22 PM
1994 Johnson 30 hp outboard tiller/elec. start sdew Johnson & Evinrude Outboards 4 October 22nd, 2003 06:52 AM
Convert pull start to electric dpropson Force & Chrysler Outboards 3 January 15th, 2003 12:43 PM
Convert pull start to electic dpropson Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 January 14th, 2003 05:50 PM
1998 Mercury 60 hp outboard won't start Deputydog Mercury & Mariner Outboards 0 July 16th, 2002 11:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
