  #1
Old August 10th, 2007, 01:18 AM
rivergoddess rivergoddess is offline
Default repair 1984 evinrude control box
Plastic part on shift lever inside control box broke, finally found replacement part, but can't remove rotating shift/throttle plate to install replacement part underneath. We removed central screw (that appears to attach to shift lever outside the box), and other apparent screws, but rotating plate won't detach. How is this plate removed so the part that fits underneath can be installed?
  #2
Old August 10th, 2007, 04:41 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: repair 1984 evinrude control box
it should lift out. has a sleave that goes over the shaft, work with it. on some there is a screw thru the shift handle from the out side, hidden under a cover plate. go to this site, cilk engine diagram, then OB Accessories, follow prompts. to your control
http://www.evinrude.com/en-US/Accessories/Literature/
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old August 10th, 2007, 05:10 AM
F_R F_R is offline
The central screw holds the handle to the round plate. It is a tapered fit so it takes a bit of persuasion to get it off. Put the screw back in (finger tight), then back it off a couple of turns. Then give the screw head a whack with a hammer. The handle will pop loose, then you can go ahead and remove the screw and handle
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Livewell control repair/replace MASTER Brian Boat Restoration and Building 2 September 14th, 2006 12:08 PM
OMC Control box on 1984 200 Evinrude ezeke Johnson & Evinrude Outboards 2 July 8th, 2006 12:12 AM
1984 Force 85 HP Voltage out of control 3scottsbaker Force & Chrysler Outboards 5 June 13th, 2006 09:13 AM
1984 Sea Horse 9.9 remote control svey Johnson & Evinrude Outboards 2 May 5th, 2005 06:27 AM
Tilt & Trim on 1984 70hp merc - control valve GAMA_BAIT Mercury & Mariner Outboards 3 October 4th, 2004 05:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
