Boat Buddy
- Jul 16, 2007
- 3
I am currently working on a boat for my buddy and don't know how to interpret what is going on with the motor. The boat is a 1992 Lowe 2200 deck boat. It has a 1991 OMC Cobra 3.0 liter motor. The problem is that when I put it in reverse and try to throttle up the motor it just kind of blubbers and smells really rich sort of like the choke is stuck. If I work the throttle a little it will usually get past it and throttle up but not without some effort.
He has already had a new shift assist module put on the motor and I have rebuilt the entire carburetor (Holley 2bbl), put in new plugs, rotor cap, and distributor cap.
All these parts and labor have made the situation a little better but not cured the issue by any means. What puzzles me is that the motor throttles us just great without the lower unit being engaged. When I engage the prop in forward gear it does great other than a very slight hesitation. But when I put it in reverse gear it falls on its face. It engages easily in both forward and reverse so it doesn't appear to be a shifting issue.
Any and all thoughts would be most appreciated.
