  #1
Old August 9th, 2007, 01:07 PM
nslsubject nslsubject is offline
Default WOT RPM for Evinrude Jet Drive?
I have an 1995 (or so) Evinrude 90/65 hp factory installed jet drive. WOT right now for my set up (16' Lowe Roughneck, side console, two 6-gal external tanks) is about 4500 rpm. Most of the posts I've seen indicate around 5500 rpm should be normal for a 90hp. My question is this: Does the different loading of a jet drive compared to a conventional prop drive account for the difference in rpm? Or does the rpm indicate some other problem? The motor seems to run reasonably well throughout entire range of rpm.
This is a new boat for me so I don't have any history to compare the current WOT rpm to.
Thanks,
__________________
"...there is nothing - absolutely nothing, half so much worth doing as simply messing about in boats." - Water Rat from Kenneth Graham's Wind in the Willows
  #2
Old August 9th, 2007, 01:51 PM
ondarvr ondarvr is offline
Default Re: WOT RPM for Evinrude Jet Drive?
I have the same setup. 90/60 on a 16' aluminum sled.
The WOT RPM's should be the same, at 5,500+, the motor has no idea of what's connected to the other end of the shaft. It's hard to tune a jet pump though, not many impellers are made for them, so you don't have many options. I don't have a tach on this boat, so I'm not sure if mine is correct either. Now that you bring this up, I think I'll go out and get one soon.
Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude jet drive franger Johnson & Evinrude Outboards 3 July 3rd, 2006 05:27 PM
'51 evinrude 7.5hp/ drive will not disengage c6rvette Johnson & Evinrude Outboards 1 November 8th, 2005 03:49 PM
Jet drive for 80 Evinrude Tacklewasher Johnson & Evinrude Outboards 2 June 21st, 2005 01:29 PM
jet drive for a 9.5 evinrude??? wayne h Johnson & Evinrude Outboards 1 June 23rd, 2003 06:58 PM
1995 28 hp evinrude jet drive erdoejr Johnson & Evinrude Outboards 1 January 12th, 2003 05:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
