  #1
Old August 8th, 2007, 10:45 PM
ReelSmokin ReelSmokin is offline
Default 115 Mariner Loss of RPM under load
I have a 115 Mariner inline 6. Recently I had the stator replaced and the engine ran great. After 4 trips I lost RPM and now only top out around 4200 but only under load. In dry dock I can redline it up to 6000. Even in the water at 4200 it sounds good, no misses, vibration, or jerking. I checked fuel by spraying gas into carbs while at top RPM and engine bogs so I iliminated that. (By the way dangerous) I checked all the pulgs, none seem to be burnt and all had a little wetness to them which is normal. Good compression in all cylinders as well. I have run out of things I know to test. Any suggestions.
  #2
Old August 9th, 2007, 03:56 AM
renny1 renny1 is offline
Default Re: 115 Mariner Loss of RPM under load
you dont say what year but i had the same trouble and it was the mixture screws on the carbs but i`m sure the experts might have a different opinion
i followed the settiung up of the carbs in the clymer manual an now she is running at 5100
  #3
Old August 9th, 2007, 09:08 AM
Laddies Laddies is offline
Idle mixture screw effect idle only not top end, you could be rich on top end caused by a leaking inlet needle or a leak in the secondary pump diaphram, have you pumped the bulb to see if it has a effect on the problem? you might have a shorted rectifier causing the problem disconnect the 2 ylellow wires at the rectifiier to ck this, or a bad bias in one switchbox causing the problem
  #4
Old August 9th, 2007, 05:15 PM
The rectifier is my next step. I wasn't sure how to test it and didn't want to chance hurting anything by running the boat without it connected. Is this really a good idea?
  #5
Old August 9th, 2007, 05:50 PM
Tadd_P Tadd_P is offline
well.. manual tells ya how to test the rectifier. So they wouldnt put it in there if it were to harm the motor. I have a 115 inline 6 mercury and had similair problems and changed my rectifier anyways. Solved 2 of my problems in one. I also had a problem with my battery going dead oh every 4-5 trips out on the water. Changed the rectifier and gained my 10 mph back and havent had to charge my battery yet so id buy a new one. Dont cost that much to replace is the way i looked at it. Being a 1979 doesnt hurt to replace parts once in a while. Good luck
  #6
Old August 12th, 2007, 11:35 PM
Well I tested the rectifier and it did in fact have a bad diode. Friday I was able to pick up a new one and install it. I couldn't test it until today and I am still having the same problem. Max RPM is 4200. Does anyone know how to test the two switchboxes? The manuel I have doesn't give any instructions for it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loss of RPMs while under load bshores Mercury & Mariner Outboards 1 July 10th, 2005 02:51 AM
Loss of spark under load FAJSAM Johnson & Evinrude Outboards 10 August 1st, 2003 07:26 AM
loss of power under load mike sumner Mercury & Mariner Outboards 1 June 27th, 2003 04:50 PM
power loss under load delsol Johnson & Evinrude Outboards 2 August 2nd, 2002 10:18 AM
loss of power under load willinfla Johnson & Evinrude Outboards 2 April 9th, 2001 03:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
