  #1
Old August 8th, 2007, 12:53 PM
Stangman Stangman is offline
Default 1967 Mercury 350 - Tachometer
I was wondering how / where I hookup a tachometer to my old Merc. I also want to know which type of tach I would need. Any help would be appreciated.
Thanks.
  #2
Old August 8th, 2007, 01:06 PM
Laddies Laddies is offline
Default Re: 1967 Mercury 350 - Tachometer
You need a magneto tach and either hook it on onside of the ign. switch or the is a nylon blockmon the engine where the mag wire come out from underneath the flywheel just remove 1 screw and hook the sender wire up there
  #3
Old August 14th, 2007, 09:29 PM
I have a tach here which states that it will work with conventional or distributorless ignitions. Will this work? Only issue I see is that it has a switch on the back for 4,6, or 8 cylinders..... And I only have 2!
  #4
Old August 14th, 2007, 09:43 PM
diaric's Avatar
diaric diaric is offline
won't work, need a marine type that has adjustable pole settings, not cylinders
  #5
Old August 14th, 2007, 10:53 PM
Will a TinyTach 2c model work?
  #6
Old August 14th, 2007, 11:02 PM
The tach that dairic is talking about won't work as it works off the alternator pulses and your engine has no alt. Go to a autoparts store and explain you have a magneto ign and it's a 2 cycle, 2 cyl engine and you need a tach if the partsman can't figure it out ck a differant place, even a place that services lawn and garden equip. should be able to get one
  #7
Old August 14th, 2007, 11:38 PM
diaric's Avatar
laddies, i've got a faria tach on my '66 500 and i'm fairly sure its magneto and it works fine. everyone here told me it was magneto when i asked about how well it should charge up the battery with accessories on it. im i wrong and its an alternator?
  #8
Old August 15th, 2007, 05:24 AM
ricksrster's Avatar
ricksrster ricksrster is offline
Quote:
You have an alternator to charge your battery. You can hook up your Faria tach by connecting the send wire from the tach to either yellow wire on your rectifier. Set the setting switch on the back of the tach to 12 pole/6pulse.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #9
Old August 15th, 2007, 10:05 AM
diaric's Avatar
i'll be damned. i guess i'm going to have to check the charging system then. it charges poorly, like a magneto system but the tach works fine. was never worried about it as i was told on here it was a magneto system
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1967 950 Mercury imported_sunshine Mercury & Mariner Outboards 7 July 22nd, 2006 06:45 PM
1967 Mercury 60 NWI Angler Mercury & Mariner Outboards 1 July 19th, 2006 03:24 PM
1967 mercury 110, 9.8 hp jwsimmons Mercury & Mariner Outboards 2 April 25th, 2005 01:59 PM
1967 Mercury 110 (9.8 Hp) mikel4538 Mercury & Mariner Outboards 5 February 14th, 2003 03:52 PM
1967 Mercury 350 parts dymo Mercury & Mariner Outboards 0 September 30th, 2002 07:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
