Mercury 4HP four stroke 2004 - doesn't START - Help
Thi sis my first boat motor, and Plese help me. I bought this from ebay and should be running great. It was transported for 2 weeks (so maybe it was transported in wrong position). Just don't have even click; doesn't want to start. I don't know what to do. Everything looks goos with engine, but just doesn't want to start. Thank You in advance for advice; Anna
Re: Mercury 4HP four stroke 2004 - doesn't START - Help
Hi, Anna.
Welcome to iboats.
Have you checked for spark at the spark plug?
Have you tried squirting a bit of gas into the carburetor?
Have you ordered an Owner's Manual?
Was it shipped with oil in it?
Does it have oil in it now?
Hi JB,
Looks like I am getting sparks,
squirting a bit of gas into the carburetor? - I will try today after work - Thank YOU,
NO Owner's Manual,
It was in oil when I got it,
I changed oil,
Hi JB,
Thank You for your advice, the motor started we squirted a bit of gas into the carburetor.
Now I have one more question, when I have low RPM I got only stem comming out from motor, when I got medium RPM I got water, and again with high RPM I got steam again. Is my cooling system work OK. Is it normal. Or I soulg see water comming out all the time. PLease Tell me.
you should see water all the time, never steam. should just be a better stream at higher rpm's. water pump impeller most likely needs changing. any running of motor without water hooked to it for cooling will quickly wear out the impeller. its not too hard of a job, easier with a manual. impellers should be changed every year to 2 years
