  #1
Old August 8th, 2007, 10:38 AM
deadduk deadduk is offline
Default '99 Evinrude 4 stroke running rough!!!
Help Please!!!! I have a 1999 Evinrude 4 stroke 9.9 hp motor that will run great for about 10-15 minutes then it will start to spudder and run really rough and then it will quit. Wait 5 minutes and it will start and run fine for a minute or two and quit again. I have changed the plugs, checked to see that the breather vent is open on the tank, and ran Sea foam through it. Anyone with similar troubles who has advice would be much appreciated.
Thanks Again--DUK
  #2
Old August 8th, 2007, 10:45 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: '99 Evinrude 4 stroke running rough!!!
did you check spark at the time it was messing up. if it were a 2 stroke i would say a coil is getting warm and failing.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old August 8th, 2007, 10:49 AM
darrklim2's Avatar
darrklim2 darrklim2 is offline
Send a message via MSN to darrklim2
Is it overheating? When it starts running rough try removing plug wires one at a time, if you remove one and it doesn't change the way it is running then you know which one to suspect. If it does change move on to the next one.
Edit. If that doesn't seem to be the problem I would suspect a fuel issue.
  #4
Old August 9th, 2007, 09:53 AM
Lastnight I cleaned out the carb and the jets. Still ran into the same problem. I sprayed fuel directly into the carb while it was running rough with no sucess. This leads me to believe that it is an ignition issue.
darrklim2--How would I know if the motor is overheating? I seem to have a fair ammount of water pressure coming out of the motor... As far as removing plug wires while running bad, would this determine if there is a bad coil? Any advice is greatly appreciated.
Thanks,
DUK
  #5
Old August 9th, 2007, 10:12 AM
darrklim2's Avatar
I'm not certain if a 4 stroke is the same but I would assume it is. After running it a while put your hand on the heads if you can't leave your fingers there for at least 5-10 seconds it is probably too hot.
Yes, removing the plug wires one at a time is a test to see which cylinder isn't getting proper spark. This can then lead you to suspect that cylinder, which could be plug wires, or the coil, or if the coil tests ok and the wires are ok then the power pack is probably suspect. Powerpacks are expensive so you want to be sure that everything else is guaranteed to be ok before replacing the powerpack.
  #6
Old August 9th, 2007, 11:48 AM
nntravel1 nntravel1 is offline
How many turns out is your main jet? My 2004 did the same thing and the main carb jet was not out far enough. It came 3 turns out from the factory it runs fine now at 5 full rotations out. When it was cold it would start and run but at full throttle it would bog once in a while, after it warmed up it would not idle or run well at all. Opened the jet at all is well.
  #7
Old August 6th, 2008, 02:16 PM
riverboatsam riverboatsam is offline
Are you sure about the breather vent,i have a 1999 9.9 evinrude 4 stroke and it doesnt have a vent. sam
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tohatsu 9.8 4 Stroke Running Rough NJS0930 Honda & Tohatsu/Nissan Outboards 7 July 16th, 2007 12:37 PM
9.9 Evinrude 4 stroke running rough question?? MikeMo Johnson & Evinrude Outboards 1 June 28th, 2007 04:21 PM
40hp 4 stroke running rough update... schmidlapp Mercury & Mariner Outboards 0 May 1st, 2006 12:37 PM
'96 evinrude 9.9 2 stroke running rough markatmfasis Johnson & Evinrude Outboards 1 May 16th, 2005 08:29 AM
Yamaha 2 stroke / 2 piston - rough running at operating temp tony_farrell Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 13th, 2003 06:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
