  #1
Old August 7th, 2007, 09:10 PM
Buttz Buttz is offline
Default bilge not working?
Well I had my boat out saturday and the bilge was working fine the first half of the day. We stopped for lunch and it started raining, when I got out to the boat I turned the bilge on and nothing happened? I do know the fuse is not blown but I havent had a chance yet to check everything else yet. Any ideas? thanks
  #2
Old August 7th, 2007, 09:54 PM
micel micel is offline
Default Re: bilge not working?
Get a current tester($5)at radioshack or any auto parts store and check for current.
  #3
Old August 10th, 2007, 05:29 PM
JAL51974 JAL51974 is offline
Check for power to the motor using a tester, but can you hear anything like is it moving only air? If so maybe the hose is loose, or plugged up? Little holes on the bottom of the bilge pump get plugged up with debris too.
__________________
"SeaDog"
1985 Bayliner Capri 1950 BR
AQ125a/270
Even a bad day on the water is better than a day at work!
  #4
Old September 25th, 2008, 04:11 PM
BBK's Avatar
BBK BBK is offline
I had the almost same problem...I found that the float was sticking just due to dirt etc...cleaned the float auot pump took over.
  #5
Old September 25th, 2008, 04:29 PM
bikemtn bikemtn is offline
If the motor is working and the filter is not plugged, etc check that the hose has constant upward placement. On mine if the hose is lower than the pump it will not work.
__________________
In Philadelphia it's worth 50 bucks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercruiser 4.3 bilge pump not working rapidrick Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 September 22nd, 2008 11:44 AM
bilge pump not working properly ? slamer12 Boat Topics and Questions (not engine topics) 4 May 25th, 2005 06:16 AM
Two stroke oil in bilge jams bilge pump switch. - 1995 Grady White story continu Osprey Boat Topics and Questions (not engine topics) 2 July 4th, 2004 07:56 PM
Tilt/Trim quits working then starts working ??? dragracer Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 September 8th, 2003 04:40 PM
Second bilge pump on the same bilge line? JerseyJim Boat Topics and Questions (not engine topics) 6 June 26th, 2003 08:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
