  #1
Old August 7th, 2007, 04:29 PM
3car's Avatar
3car 3car is offline
Default aluminum fuel tank repair
I have a grady white 204c, and while removing the fuel tank for cleaning I made some discoveries. The tank has some corrosion damage. It has been welded in a couple spots, and fiberglassed in a couple more. I went to a local supplier to replace the tank today, but I found that my tank seems to be an odd size. I have decided to repair it to get me through the year, and probably have a custom tank built. The old tank isnt leaking, but my goal is to keep it that way until I replace it. What is the best wat yo patch up the corroded areas? Some type of epoxy? What about the previous fibergalss repairs?
  #2
Old August 7th, 2007, 05:59 PM
dingbat's Avatar
dingbat dingbat is offline
Default Re: aluminum fuel tank repair
I was fortunate and my tank on my 1986 204 was in great shape. It's was just my fuel hoses that had gotten old and where leaking.
If it's been patched that many times it's on its last legs and needs replaced. All you need is a catastrophic failure and you end up with 62 gallons of fuel in the bilge.
The tanks where custom for Grady by RDS in Perry Fla. and Florida
Florida Marine Tanks, near Miami. I understand that some of the new 20' Gradys have poly tanks so you might check around for one of those as well.
  #3
Old August 7th, 2007, 08:35 PM
garycinn garycinn is offline
check out www.oceanlinkinc.com for lots of options.
  #4
Old August 7th, 2007, 08:59 PM
tommays's Avatar
tommays tommays is offline
This is really just a place were you can not CUT corners
There are just to many other people around your boat that would be injured or worse
Tommays
  #5
Old August 7th, 2007, 09:10 PM
David B. David B. is offline
I know a guy that took his aluminum fuel tank to a welding shop to get fixed, he said it didn,t cost much
  #6
Old August 7th, 2007, 11:09 PM
wncrjb wncrjb is offline
I just go my 23 gallon aluminum tank back today from getting repaired. I had some corrosion damage in the bottom of it. I had the the old bottom cut out and a new one welded in. It cost me around $ 100.00.
I know a new poly tank would be cheaper but I like to keep things original when possible.
wncrjb
  #7
Old August 9th, 2007, 03:22 AM
reelfishin reelfishin is offline
The in hull tank in my Hydra Sports had a badly corroded filler neck, I took the tank out, drained and cleaned the tank out and cut out the bad spot and welded in a new filler spout. I also reinforced that area so it won't be a problem down the road.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum fuel tank repair? blacktip18 Boat Restoration and Building 13 August 15th, 2007 12:23 AM
removing Aluminum Fuel tank doctorrazz Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 March 22nd, 2006 05:56 PM
installing above deck aluminum fuel tank 93bronco Boat Topics and Questions (not engine topics) 2 August 28th, 2003 04:21 PM
aluminum fuel tank 12 years old bonitoman Boat Topics and Questions (not engine topics) 3 March 3rd, 2003 05:09 AM
aluminum or plastic fuel tank? kjpfish Non-Repair Outboard Discussions 20 December 30th, 2001 07:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
