I have a 1998 Mercury 200hp which is overheating at cruising speed. At idle, it operates at normal temp, but if I take off, the overheat alarm will come on within about 2-3 minutes, at which time I immediately pull back to power to idle, overheat alarm turns off within 1 minute once engine cools down. The impeller was replaced 1 year ago and the water pump seems to be pushing out a constant stream. Engine runs very well except for this. I have done the following so far:
1)Replaced the Thermostats
2)Pulled off the heads, looked for damage (cylinders, pistons, head gaskets looked ok), replaced head gaskets, reassembled
3)Opened poppet valve housing, poppet valve seemed to actuate ok, replaced poppet valve rubber diaphram, reassembled
Engine is still overheating at cruising speed. Not really sure what to try next. Any thoughts?
