I'm trying to replace the mechanical fuel pump on this 82 mercruiser 360. It seems that this works on a push rod but I'm not sure. If it is a push rod what is the trick in pushing the push rod up so I can slip in the new fuel pump. There isn't a lot of room there so its a little tricky. Also there is a metal plate that is between the pump and the block, should I remove that to push up the rod? Help, this thing is wearing on my brain.
