Ok, I'm 100% new to boat motors, but I do have mechanical experience working on motorcycle engines (spec old Suzukis)...
I just picked up a 'free' boat with the aforementioned motor... The boat seems to be in good shape, although the interior needs cleaning/painting - it's been sitting a while....
The motor is apart, apparently the prior owner managed to fry the lower part (I think it's called the 'leg' - the part with the prop in it), and a 'good' one was included along with the original...
A bunch of the wiring was disconnected up in the engine area, presumably to get the motor case pieces off to remove the bottom...
So, where do I start in 'reactivating' said motor? Can I run it with the 'leg' removed, if I run garden hoses from the 2 pipes into a trash barrel (I assume the 2 pipes coming down from the motor are coolant in and coolant out)...
Where do I get info to see that the wiring 'up top' is as it should be?
I assume this is a 2-cycle motor and I need to feed it 'oil-gas', right?
Any other advice?
I'm pretty good mechanically, I just have ZERO power boat & boat motor experience...
Oh...
How do I get this thing to drop down... It seems to be stuck in the 'up' position, and I can't find anything to indicate it has electric tilt.... So I'm assuming it's manual tilt... Should it tilt easily? Is it a corrosion issue, or am I not looking hard enough for a mechanical motor-tilting system of some sort?
Any other advice?
Oh...
