  #1
Old August 6th, 2007, 12:51 AM
cionjay cionjay is offline
Default 1994 Evinrude 175HP V6 60deg with no reverse or forward gear
I am trying to figure out what could be the problem. I was cruising and all of a sudden the lower unit pops out of gear. I can not get it to go forward or reverse. when i shift it foward i can see the linkage move and the shift rod move when i move it. I have a shop manual but it does not say anything about this problem. The shift cables feel stiff when i put it in foward and reverse. Any help with this would be greatly appriciated.
Thanks
  #2
Old August 6th, 2007, 01:06 AM
Default Re: 1994 Evinrude 175HP V6 60deg with no reverse or forward gear
I forgot to mention that when i put it in gear I hear no grinding and never before eard any grinding and the engine will rev up when I try to put it in gear both for foward and reverse. The prop just will not spin.
Thanks
  #3
Old August 6th, 2007, 04:38 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Welcome to iboats. several possiblities. bad cable., disconnect at engine, and move the engine linkage manually. the next is a spun prop. the prop is made of an inner and outer metal hub. connect with a pressed in rubber bushing. this bushing is known to fail, and is there to protect the lower unit, if the prop hits something. draw a line across the prop as in the picture. give it a try in the water, if the line is still lined up it is not the prop. from here the senario get worse.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old August 6th, 2007, 10:20 AM
I will try this when I get home from work today. thanks
  #5
Old August 6th, 2007, 10:31 AM
Walker Walker is offline
Also the possibility of a broken driveshaft or clutch dog.
  #6
Old August 6th, 2007, 01:21 PM
ezeke ezeke is offline
It is faster to check for a spun prop by using the cotter pin as a pointer and simply making your index mark on the outer hub. That way you don't need to remove anything.
  #7
Old August 6th, 2007, 09:49 PM
I did as you said. i can hear it shift up and down but nothing will engage and the prop marks do not move. If it were the clutch dog I guess i would hear some kind of grinding noise, but in my case i do not. so i would imagine that it is the drive shaft that broke. I am scared to find out how much money it would cost to fix it and i'm not sure if i want to sink any more money into this motor. maybe i can talk to the wife about buying the E-tec. Thanks for your help.
  #8
Old August 7th, 2007, 01:52 AM
Lightbulb Re: 1994 Evinrude 175HP V6 60deg with no reverse or forward gear
I was wondering if this motor has an electronic idle mech. because on the controls there is a button that can be pressed and you can then move the controls foward to rev up the engine when it is cold. if there is such a thing how would i check this.
thanks again,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gear box stay in forward when using reverse redmapleleaf Mercury & Mariner Outboards 5 July 13th, 2007 11:28 PM
Forward and reverse gear very stiff Danny_P_G Johnson & Evinrude Outboards 5 July 19th, 2006 03:20 PM
flip flopping reverse gear to forward brokeboater Johnson & Evinrude Outboards 3 October 5th, 2004 08:50 AM
forward/reverse gear problems fish4food Force & Chrysler Outboards 1 July 1st, 2004 07:32 PM
66 johnson forward/reverse gear question Furter23 Johnson & Evinrude Outboards 3 July 1st, 2002 06:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
