  #1
Old August 5th, 2007, 11:30 PM
rdkornack rdkornack is offline
Default Mercury 125 EXLPTO Power Loss
Need some help.
Motor was running find on local lake 35-38MPH, Tach not working (RPM ?), all other gages OK. After running aboult 15 min., motor slows down to 15MPH at full throtle. Can not get back up to speed. Starts up very easy and idles a little rough. At hole shot, motor seems to want to increase but cuts out quickly.
Changed plugs and fuel filter, no change. Found plugs #3 & #4 cylinders cleaned compared to #1 & #2 (dark brown). Checked for spark, all Cylinders have spark (nice blue). Switch Modules around and problem stays on #3 & #4cylinders. Charging system works find, 12.2 VDC with ignition on, 14.1 VDC running.
Sprayed starting fluid in #3 & #4 carbs, motor increases speed and engine sounds better until burn thur. Sprayed in #1 & #@ carbs, motor wants to stall. Check all fuel lines, OK. However, fuel blub seems a little soft when running. Fuel in all bowls and clean, all jets clean.
Data for www.outboardparts.com states
Stator OHMS 600-700, measured 682.
Trigger 800-1400 OHMS, measured 1271 to 1850 (not sure this is correct)
Seems like a fuel system problem or possible electrical.
Any info. is appreciated.
Bob
  #2
Old August 6th, 2007, 01:05 AM
Derric Derric is offline
Default Re: Mercury 125 EXLPTO Power Loss
Hey, my 90hp 2 stroke did the same thing. Only I have individual coils for each spark plug and found that the #3 coil went out and so did my switchbox. Good Luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 115 power loss brad1975 Mercury & Mariner Outboards 2 July 9th, 2007 04:03 PM
Mercury 3.0l Power Loss Maxum3 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 July 7th, 2007 12:04 AM
Power Loss on Mercury 9.9 boaterchal Mercury & Mariner Outboards 1 May 9th, 2006 03:21 PM
115 Mercury power loss jimmydod Mercury & Mariner Outboards 10 March 20th, 2004 06:56 AM
Mercury 200 EFI Loss of Power boatmike2 Mercury & Mariner Outboards 0 August 30th, 2002 07:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
