Re: Noise
Redtech,
Thanks, again! for the reply, I didn't think changing oils would help, as a matter of fact a friend who is a boater and an automotive mechanic sugested that a lighter oil would give better lubrication not heavier. He also asked me if I have ever goten water in the rengine, which I supose is not imposiible to do with the engine off and at anchor or adrift.Water can get in from the exaust outlet, But then again the oil is perfectly clear.
Agent 37 make sure you did not get water in your engine. The noise you describe is diferent than the one I had and suposedly caused by an out of balance krang shaft. That noise was coming from deep nside the engine furthest away from the flywheel and I was able to hear it only at Idle, when thottle was applied other noises masked it. I am afraid I don't have any ideas I would use a stethescope to try and pin-point where the noise is coming from. I hate it when you baby engines and give you trouble, yet others who don't care about maintenanace seem to be doing just as well or better.
Thanks to the both of you for your input.
