  #1
Old August 5th, 2007, 05:46 PM
gibby6117 gibby6117 is offline
Angry Mercury 70 hp hard to start
Any help would appreciated I hae a 1989 70 hp merc 2 cycle 3 cyl. It only has about 200 hrs on new engine. new gas lines and new Johnson/everuide primer bulb. The primer will get hard after 6 or 7 pumps and motor won't start at all even with choke on. It is strange as I can sometimes wait a hour or two and it starts right up . and it all ways will start at the first touch if it has not sit mre that a few min . Motor runs perfect after start . I believ3e the choke is the kind that just pumps gas into the carbs and it has just been replaced.
  #2
Old August 5th, 2007, 06:16 PM
Laddies Laddies is offline
Default Re: Mercury 70 hp hard to start
Your engine has a primer on it, not a choke it's a fairly simple system, when you pump the bulb up it fills the carbs, when you push the primer it opens a valve that lets fuel travel thru a line and prime the bottom 2 carbs. Reasons it won't work 1. the top carb has no fuel (stuck inlet needle) 2. the line between the carb and primer unit is obstruted 3. the primer it's self is plugged or not working. 4. the line from the primer to the carb or the fitting that lets the fuel in the carbs are obstruted
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 3.5hp hard to start bhcky79 Mercury & Mariner Outboards 3 July 21st, 2007 10:47 PM
mercury 3.5hp hard to start bhcky79 Mercury & Mariner Outboards 0 July 13th, 2007 08:06 PM
88 Mercury Hard to Start Mark A. Spencer Mercury & Mariner Outboards 3 July 11th, 2005 05:08 AM
50 Mercury Start but hard to stay start. mann Mercury & Mariner Outboards 1 July 26th, 2002 02:26 PM
Hard to start 115 mercury outboard juiceisu Mercury & Mariner Outboards 3 June 7th, 2002 08:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
