Head bolt sealant
jdtower23
Can anyone tell me which head bolt holes exactly need sealant because they are in the water jacket? Engine is 4.3 OMC '88...also, what should I apply on the ones that don't go into the water jacket?
Thanks!
Bt Doctur
Re: Head bolt sealant
All the head bolts enter the water jacket, all need sealant
Permatex Aviation Sealant works nicely.
jdtower23
Will Permatex #2 work? I haven't seen the aviation stuff in any stores yet....
Bt Doctur
it should ,I`ve always used a liquid type.
Most good auto parts shouold carry it or order it .
jdtower23
I looked it up, and I actually have seen it before....would it be worth it to go ahead and buy the Aviation if I already have the #2? What's the advantage of the liquid type?
Thanks
Bt Doctur
comes in a big container with a brush attached to the cap, fingers don`t get coated along with the bolt,impossable to step on and get it all over the boat.
When replacing the bolts it`s a good idea to clean the block holes with a tap and to wire brush the bolts clean.
Don S
Then with the liquid, it makes a nice even coat so it's fast, easy, and it doesn't affect the torque if you do the above first.
