Prop pitch for 84 capri 195 aq125/270 OD
Does anybody have the application chart for props? If so, could you PLEASE tell me the proper pitch for a 1984 Bayliner Capri Cuddy 19.5 ft, with the Volvo AQ125 4 banger engine and 270 outdrive?
Also- max rpm's right now are about 4500. The engine may be getting a tad tired, (compression is good though) or it could be the giant dings I have out of the current prop. I don't know what the proper max rpm's should be..... There is minimal marine growth due to anti-foul paint, if that comes to mind.
I have 2 spare props. One is toast- its a 14x19 RM2. The other is mint, but you can't read the #'s... it seems a little bit steeper, all I can read is x..9..R
Thanks!
Dan
