kingfish999
- May 17, 2007
- 4
ive been working on my 1hp 1976 evinrude for a while and the enine won run unless i pull out the choke every second or so. i beleve its the fuel pump not pumping. i pulled off the fuel hose from the pump to the carb and started the motor and no fuel was being pumped out. after, i took the fuel pump apart and found some gunk in it but i dont know if thats whats causeing it. im putit back together now but i have a little spring with a nub. i know its in 1 of 2 areas wherefuel sucks in gas and where fuel pushesout gas but not sure which. also i dont know if there was another of this spring. this is the fuel pump i have http://www.boatmotors.com/mall/part...&gd_poid=109266&gd_row=5&**********=545028355. so questions are:
1: can there be another reason my engine stalles like this?
2: do i need a new pump or can i get this old 1 to work?
3: are there 2 of these springs with nubs or just 1?
4: where does this spring go?
5: was this a good test to do since i dont have a fuel pressure gauge?
any help will be apprecited. i might not be able respond for a week becuase im going out of town
