Re: 1987 omc 3.0l
There is a stainless steel plate inside the drive. It's there to keep water from erroding the aluminum housing away. When you remove the screw, the plate falls down inside the water passage. You will have to remove the drive roll it around till you get the plate back in place and screwed down. Use some red loctite to prevent the screw from being removed again.
